Home > Off Topic > Brake light bulb on VW Golf Mk5
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Have perused the VW forums - loads with this issue but no solutions
The rear right brake light bulbs keeps blowing and the car computer lets me know.
Sometimes its not the bulb though as after a while ( a couple of days) the "bulb not working" sign goes off and the brake light works again
I have checked with a meter and the bulb is getting 13.8v when brake pedal is pressed
I am using Bosch bulbs ( Made in Russia) from Halfords (with the recommended wattage 21W, 12v)
There are other bulbs in the same cluster that work fine and never blow out.
Any ideas?
Post #454633 13th Sep 2015 11:33am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Switch to LED's Thumbs Up
Much more tolerant to changes in voltage and vibrations etc
Just make sure you get the CANBUS compliant bulbs Thumbs Up
Post #454719 13th Sep 2015 5:46pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Bad earth?
Post #454721 13th Sep 2015 5:48pm
kmac
How do you check for bad earth? At what part of the circuit?
Post #454768 13th Sep 2015 8:35pm
