Home > Technical > windshield wiper switch |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Hello !!
During some proactive maintenance I manage to disconnect the 8 colored cables behind the windshield wiper switch. Does anyone has a photo or the correspondence between colors and numbers?? My defender is a 2001 td5 110. Augusto Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
9th Sep 2015 3:22am |
Click image to enlarge |
9th Sep 2015 8:03am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
If its the early type rotary on off and push to squirt wash I don't think its changed from 200Tdi in which case here is what mine looks like, if it helps
Click image to enlarge Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
9th Sep 2015 9:39am |
thanks shaggy and dorsetsmith, I had the drawing but what I disconnected is not the white flat connector with 6 cables but the 8 cables that split from there into the copper posts on the switch. Augusto
9th Sep 2015 11:34am |
Finally find a photo with the correct connection they are as follows
Post behind switch Color Cable Flat Conector 1 Blue green 2 Brown Green 3 Brown Green and black 4 White Green 5 Yellow Green 6 Red Green 7 Red Green 8 Red Green Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
11th Sep 2015 10:16pm |
