Home > Maintenance & Modifications > Mounting Plinths - NAS style lamps
discomog
I am in the process of converting my existing original equipment 73mm rear indicator lamps to 95mm NAS style LED�s. I want to avoid drilling any additional holes in the rear bodywork and would like to use the existing holes. Does anyone know if and where I can obtain some plinths from that meet this spec?
Post #453956 10th Sep 2015 3:42pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Post #453958 10th Sep 2015 3:53pm
Martin
Site Admin
As long as you are using LED throughout you can use the SVX plinths on the rear, part number LR009773
This is for the rear only, on the front you would have to use an aftermarket stepped plinth.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #453959 10th Sep 2015 3:55pm
discomog
Hi Guys, many thanks for your quick responses.
Mike_B. The Bolt on Bits are exactly what I want. I'm in Bradford on Monday so I will call in and pick a couple up.
Martin. I'm only fitting NAS style on the rear. I'm putting Mobile Centre lamps on the front
Post #453966 10th Sep 2015 4:55pm
Griff_L322
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Bolt on bits easy fit are perfect for a quick fit.
Had them front and rear on our td5
Post #454074 11th Sep 2015 6:53am
