Home > In Car Electronics > Tweeters |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6628 |
The crossover is in the standard tweeters, and they are 1".
Plenty on here if you do a search http://www.defender2.net/forum/search.php?search_keywords=tweeter 1988 90 Td5 NAS soft top 2015 D90 XS SW |
26th Aug 2015 1:16pm |
Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744 |
The scary bit is I DID search and still didn't find the answer
26th Aug 2015 3:24pm |
Davegouldenpuma Member Since: 10 Sep 2015 Location: staffordshire Posts: 1 |
Martin you show the Alpine tweeters that are standing up proud of the dash where can i get them??
10th Sep 2015 7:14am |
Google it.....plenty of options there from £19:99 upwards!
Following part numbers may help! SPS-110TW SPR-10TW If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Sep 2015 7:26am |
Just a word of caution in that with the Puma the way that the dash is moulded with a slight rise it makes the fitting of Alpine 1" tweeters less than absolutely perfect. Yes they will fit the hole (with a bit of fettling) but the grille edge will overlap the raised contours. You might have the same problem with pods.
I've seen suggestions that the Focal tweeters are a better fit but I've never seen any pictures in the flesh to prove that. Personally I decided to re-use the existing factory fit tweeter grilles. See my thread here: http://www.defender2.net/forum/topic39623-15.html HTH |
10th Sep 2015 7:43am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Your wish
Click image to enlarge |
10th Sep 2015 8:57am |
Excellent thanks Ken.
That picture also shows the raised area of dash clearly too which I reference in my post. By the way upgrading the factory fit tweeters has a HUGE impact on sound quality. |
10th Sep 2015 10:16am |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Focals look good and do an admirable job on top and under the dash... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
10th Sep 2015 12:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
Indeed, but it'd be the last item I'd choose to upgrade of the lot in order of importance. They can all wildly differ in price too. |
12th Sep 2015 10:13pm |
MGDM4 Member Since: 28 Aug 2015 Location: Leeds Posts: 45 |
Is Focal the only make of speaker that people use?
What would fit in an 04 TD5? Matt |
4th Nov 2015 10:02pm |
