Home > Maintenance & Modifications > Sikaflex 221 |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Silkaflex is great stuff, I used it to seal the hard top to the body cappings due to a leak, worked very well, just make sure you have something wet like a damp J cloth when doing it, it's easier to wipe and get smooth with something wet or damp, like when plumbers lick their fingers when sealing the edge of the bath.
9th Sep 2015 7:42pm |
Sonarmender Member Since: 04 Apr 2013 Location: Guz Posts: 338 |
If you are expecting to bond the bracket you will have to 'key' both the bracket and the area the bracket is to be bonded to, or else eventually the bond will break.
You only have one life, live it....forget the cost. 90XS Hardtop |
9th Sep 2015 8:11pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
My snorkel is bonded to the frame with sikaflex. I didn't etch the surfaces. Still stuck. Just left it to cure for 24/36hours held in place with a ratchet strap.
9th Sep 2015 8:25pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20578 |
I'd have thought a glossy surface would be a better bond for a sealant / adhesive in this instance with less possibility of moisture getting behind it.
9th Sep 2015 8:50pm |
I don't know but my fish tank certainly ain't etched/roughed up where the joins are and there's 400kg of water being held in by the sealant. So my snorkel being attached the same way worked for me.
Sikaflex sets upon contact with moisture. So shouldn't be a problem. |
9th Sep 2015 9:11pm |
Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129 |
Silkaflex is great gear I use it all the time although it is very strong & works well as a bonding agent
for a while, I would be looking for a more permanent fixing, but it saves drilling unwanted holes in the body work!! When you come to finishing off the beading have a spray bottle with some fairy liquid & spray the Silkaflex & your hand then run your finger along the bead it will give you a nice smooth finish plus it wont stick to every thing you touch |
9th Sep 2015 9:13pm |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 |
You can buy it in Screwfix it's Sika EBT,I used quite a few tubes when building my camper van,stuck the solar panels to the roof with it .You do need a minimum of 2mm thickness of Sika though.
10th Sep 2015 6:03am |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
Sikaflex is the real deal. That bond will outlast the rest of the defender..
10th Sep 2015 6:09am |
I have used the same Sikafelx for exactly the same application and it has worked a treat:
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Sep 2015 7:33am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Sikaflex is brilliant stuff but think about the job logically, you are not gluing the bracket directly to the screen frame, you are gluing it to the paint on teh frame. Therefore the bond to the screen frame will only be as good as the bond the paint and primer has to the frame itself..... Steve.
10th Sep 2015 9:47am |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
my snorkel isnt the same as that but i used small stainless nuts and bolts to hold the bracket onto the window frame (with v.careful drilling) and then a blob of sikaflex to make it all watertight.
10th Sep 2015 12:09pm |
