Home > Technical > LT77 Strange 5th Gear |
Mike.s Member Since: 19 May 2015 Location: Weymouth Posts: 30 |
I`ve just checked the serial numbers - my old gearbox is a 50A suffix G and the new box is a 51A MOD box.
Could the linkage on the 50A be different to the 51A? I checked the old and new box - without the selector mechanism, 5th gear is definitley different on th etwo boxes. On the 50A box, the selector has to be pushed all the way over to the right, then forwards. On the 51A box, it has to be pushed all the way right, then backwards. I did notice that the stick appears to have been welded at some point - i presume to be fixed as it may have snapped in the past, but maybe not? Here`s pics of the selector mechanism on the new box - Click image to enlarge Click image to enlarge |
7th Sep 2015 9:15pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I think your best bet would be to give Ashcroft Transmissions a ring tomorrow as they will know exactly what you need.
I have never known a LT77 to have a 5th gear as select right then down, only ever as right then forward. Is this the one which has the much lower 1st gear? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
7th Sep 2015 9:24pm |
Yes - it should have a slightly lower 1st and 2nd.
I`m only presuming its 5th gear - i have no props connected at the moment and can`t drive it. Reverse is definitely in the right position - you can hear the distinctive clack when it selects. 1,2,3 and 4 all appear to be correct locations aswell. |
7th Sep 2015 9:39pm |
I had a closer look in the light this morning and it looks like there is a collar which should slot into to the selector(?).
This is mine - the selector is pushed all the way over to the right. I tried to lightly push it back, but it felt pretty jammed and i didn`t want to break anything. Click image to enlarge You can see on this pic i found where it slots in. I have a pic from when i boiught it and mine looks aligned then, so it must have come out somehow and then attempting to select 5th has pushed the selector ring back and jammed it. Click image to enlarge Should it come back easily or can i rotate, the collar, etc and then pry it back with no damage? Thanks, mike |
8th Sep 2015 7:36am |
Just a quick update as i think i have hopefully sorted it.
I have no idea how the interlock cam disengaged from the selector, but i ended up carefully removing the circlip on the selector, then sliding the collar back. I could then push the selector back into position and re-engage the peg form the interlock. Pushed the circlip back on and with the linkage back on, everything seems to be moving how it should be. 5th seems a little sticky/stiff, but hopefully with some oil in the gearbox, it will get a little freer |
8th Sep 2015 6:19pm |
