Home > Maintenance & Modifications > Washer Jets Not Working.
maxlomax
United Kingdom 2010 Defender 110 2.5 TD SW Corris Grey
I have a 2010 Defender 110 Station Wagon and the main front screen washer jets are not working. I have put a pin in to both holes but I only get a tiny trickle out of one. The pump makes a noise and the rear one works fine.
Post #453049 7th Sep 2015 3:41pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Remove the pump, and make sure it's clean and working freely.
Blow all the water pipes through with compressed air.
Might pay to flush out the washer bottle while your at it!
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #453059 7th Sep 2015 4:03pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
There is a non-return valve on the plastic pipe, up near the bulkhead. Make sure this isn't blocked up, Does it come out of the pipe with any force with it removed.
Post #453064 7th Sep 2015 4:20pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
99% of the time is the non-return valve Thumbs Up
Post #453135 7th Sep 2015 8:07pm
