Home > Puma (Tdci) > Viscous fan bearing ? |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 323 |
It seems the fan pulley bearing is only available as part of the bracket and bearing assembly PQS500620
Be aware the fan is a left hand thread onto the pulley and usually is very tight (still not managed to get mine off yet) |
6th Sep 2015 8:20pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
The fan bracket is held on by 3, 14mm bolts that bolt through the timing chain cover.
You can undo these without taking the fan off (just!) Photo is not much of a help, but they are fixed just under the block where the top hose enters the block. Click image to enlarge Easy to Change though, once you've got all the other stuff out the way! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
7th Sep 2015 6:12am |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
Do I have to take the timing case off also ?!?! I was hoping not
Thanks for the replays so far chaps |
7th Sep 2015 4:13pm |
No, don't worry!
The photo was just to give you an idea of where the fan bolts to. This was in for timing chain replacement. Look where the top hose goes into the block, (centre top) The holes underneath are where the fan bolts to, through the chain cover. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
7th Sep 2015 4:38pm |
