Home > Maintenance & Modifications > upgrading std landrover door locks
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Today ive fitted new locks in all my doors, but since I've learned that one of the weak points of std landrover door locks is down to the brass pin that is used to locate the lock in the door.
Has anyone tried drilling the brass pin out and then drilling and taping both it and the door handle to accept either a small bolt or grub screw? I had to drill a pin out of the old lock to get it out the door so I know that the pin can be drilled.
My thinking is this would be much harder to break and could potentially buy extra time till the scum bags smashed a window or similar
Post #452484 5th Sep 2015 2:17pm
Dave_S
Proper deadlocks are the only real answer I guess...
Post #452597 5th Sep 2015 8:33pm
Griff_L322
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
No point doing anything to the locks unless you change the hinge bolts to a more secure type
Post #452656 6th Sep 2015 7:19am
gazman
Cheers. I didn't think about just taking the doors off! Rolling with laughter
Although I'm gonna put split pins through the inside of the bonnet bolts so it can't be unscrewed.
Post #452662 6th Sep 2015 7:53am
gazman
Post #452665 6th Sep 2015 8:02am
