Home > My Defender > My New Runabout
Page 2 of 2 <12
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
BarneyRubble wrote:
Makes it an expensive holiday!
Yep, the most I have ever spent on a holiday Very Happy
Worth it though! MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #37619 4th Aug 2010 11:41am
110SEB
Grockle wrote:
just a note, spray plastic bumper dressing on the side steps to stop them rusting after cleaning
Top tip! Thanks, Grockle Thumbs Up
Post #37623 4th Aug 2010 12:42pm
Grockle
Paul55 wrote:
Grockle wrote:
just a note, spray plastic bumper dressing on the side steps to stop them rusting after cleaning and get some plastic nut caps as the bolts will rust in front of you(Component Force in Kent)for the nut covers use them on the towbar nuts and bolts too
Talking of nut covers, you still got mine Big Cry
don't know what ya on about Whistle 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #37624 4th Aug 2010 1:06pm
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Latest Mods
Latest modifications:
Insulated and boxed in the wheel arches using 1" plastic/foam insulation and 6mm oak veneered MDF (left overs).
Insulated and panelled the sides with loft insulation and 13mm oak veneered MDF.
Insulated the floor with 1" plastic/foam insulation and cut the load liner to fit.
Had a Parrot MKi9200 bluetooth phone kit fitted.
Fitted the replacement variable intermit wiper relay as per dgardel's excellent find - http://www.defender2.net/forum/topic1810.html
This then got me thinking about the rear wiper, I never need to have the wiper on permanently and it really annoys me having to push the button every 30 seconds, so after consulting the font of all knowledge (dgardel Bow down ) I came up with a way to add the same variable intermit relay to the rear wiper system.
wiring diagram:
http://www.defender2.co.uk/gallery/albums/...ations.pdf
Don't look too closely at the wiring - not the best (especially for an electrical engineer). Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #45214 14th Nov 2010 12:55pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Looking Good.
I did a camper van conversion, after checking I did not install fibre glass loft type insulation as it holds mositure. Check what you have fitted, the reports i read were that the insulation holds mositure in, turns into a black sludge and rots the car from the inside out.
I used Thermafleece on the sides and isonat on the roof, both natural fibres which dont hold mositure, both available from camper conversion websites, easy to fit and doesnt make you itch.
Post #45256 14th Nov 2010 8:22pm
BarneyRubble
Jate Rings
Latest Addition: Jate Rings
Had to use some temporary bolts as finding it hard to get the right size bolts for the right price.
 Barney
Post #51540 7th Jan 2011 12:28pm
BarneyRubble
Latest additions:
1) Bumerettes - thanks to Mark_110DCPU
Using chiefstoker's excellent guide http://www.defender2.net/forum/topic6033.html I "adjusted" the mudflaps to suit. - I'm amazed at the c**p quality of the mudflap paint - for a vehicle less than 2 years old there is so much rust!
2) Nakatewhatever Rear Door Stay - thanks to Brendan (Leeds)
Very easy to do, excellent instructions, a bit panicky when drilling the rivet holes, but soooo worthwhile! Barney
Post #147475 29th May 2012 7:24am
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
Bumperettes look good Smile - Was good to meet up with you. Really nice looking truck generally too. Shame mine doesn't look that tidy!
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #147481 29th May 2012 7:58am
BarneyRubble wrote:
Latest additions:
I recently fitted one too and I was the same. You've got to be so careful that once the bit goes though it doesn't peirce the outer skin as well Shocked A drill Step bit would probably been more suitable.
Post #147482 29th May 2012 8:06am
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Very easy to do, excellent instructions, a bit panicky when drilling the rivet holes, but soooo worthwhile![/quote]
I recently fitted one too and I was the same. You've got to be so careful that once the bit goes though it doesn't peirce the outer skin as well Shocked A drill Step bit would probably been more suitable.[/quote]
Put a cable tie on the drill bit, that will prevent you drilling through too far Thumbs Up Richard
Either a 90, 110 or 130.
Discovery 5
Post #147529 29th May 2012 12:46pm
Page 2 of 2 <12
