Home > Maintenance & Modifications > Touching up
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Touching up
I have been sent a touch up kit which has paint and a separate laquer. I presume it's as simple as doing the colour bit, waiting for it to dry and then dobbing on the laquer. Not supposed to mix them together am I?? (Metallic plaint by the way)
Post #451776 3rd Sep 2015 11:58am
Rickydodah
You've got it right Jonno, colour first and lacquer when colour is dry. Thumbs Up I started with nothing and still have most of it left!
Post #451779 3rd Sep 2015 12:05pm
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
Jonno1968
The advice from Rickydodah is spot on.
There are lots of good tutorials on the Web/Youtube about how to complete these repairs well.
If its larger/visible, then its worth looking at these, I generally build the paint up above the surrounding undamaged area, then cut it back, the best way to do so is with very light abrasives then finish with a cutting polish to restore the gloss finish.
If you want to do that, I'd recommend:
https://www.paints4u.com/ProductDetails.aspx?productID=2309
https://www.paints4u.com/ProductDetails.aspx?productID=3569
Then a good cutting compound, such as 3M
take your time and as long as you have a good match with your paint, you can make stone chips disappear!
Post #451817 3rd Sep 2015 2:23pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Chipex is another alternative for the DIY.
Post #451930 3rd Sep 2015 7:02pm
