Home > Group Buys > IID BT @ £365 - Running on DISCO3
Lost for Words
If anyone is interested, there's a group buy being run by Disco_Mikey for an IID BT @ £365 over on DISCO3. This is the second round, the first offer being taken up by over 30 people! Though it's only a small saving, this is the best that can be done and you won't find it cheaper. Wink
For those that don't know, the IID is an excellent diagnostic tool, with great service from GAP Diagnostic. It's reliable, safe and user friendly. The Defender (2007-on) is a more recent addition and, while coverage may currently be a bit more limited, it is being constantly developed. Smile
http://www.disco3.co.uk/forum/topic133849.html
http://www.gap-diagnostic.com/products/iidtool.html
Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #450524 30th Aug 2015 8:36am
Lost for Words
Already got 10 people now, but more still welcome. Thumbs Up Visiting from DISCO3.CO.UK
Post #450784 31st Aug 2015 9:52am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
A bit more info, for anyone sitting on the fence Wink
You can get details of coverage here: http://www.gap-diagnostic.com/products/iidtool.html
For the BT model, the basic functions (fault codes, live data, component control and service routines) are unlocked and available for all covered vehicles. Enhanced functions (CCF editing and ECU flashing, and calibrations like the suspension, transfer box and SAS) are VIN locked. You can buy additional licences (for any covered model) for £60.
The device works best via bluetooth using an app (free - Android and Apple), allowing graphing of live values etc., but can also function on it's own using the instrument cluster to write on like the IID "classic". (NB: Not all Android devices are compatible, so best to check first.)
Having worked my way through various diagnostic tools over the years (IDS/SDD, Autologic, Faultmate, Haweye, Nanocom etc), the IID Tool beats them all hands down, for ease of use, accessibility, info provided, and above all else, price...
The IID Bluetooth unit is exactly the same as the IIDPro which I use on a daily basis, but is VIN-locked, as explained in the above. The only difference is the Pro version is VIN-Free, and the price.
The IID will perform functions that even JLR's own SDD diagnostic system cannot do, such as Sat Nav on the Move (allows you to enter destination while driving)
It allows FULL Car Configuration File (CCF) editing and allows you to unlock "hidden" features within the car
It allows full software updates (not all models are currently covered, but they are in the pipeline), some of which as required for CCF editing and features to work, such as 3 Flash Indicators.
It allows EAS calibration, either individual corners, front only, rear only, or all 4 corners.
And if it all goes wrong with a calibration, or CCF editing, there is a Restore function, to put it back to standard Thumbs Up
There has been much thought and care put into each, and every process the IID Tool can perform.
They even go as far as forcing failed software updates, and have recovery processes already in place. Most of which goes on in the background automatically, so the end user doesn't have to do anything
I have taken some screenshots with my own Disco 3. There will be differences between the models, and some features available on some that are not there on others.
Fault Code read/Clear
You can also email them to yourself for future reference, or easy copy/paste. The forum software sees 8 + ) together as Cool Whistle
Quote:
VIN: SALLAAA135A336942
Vehicle scanned on 31-08-2015 13:30
Using IIDTool Pro V3.0 B2520
Auxilary Heater
U1A44-6C (2E) Fuel level
Body Control
B1B56-87 (2Cool Sliding roof module - Bus signal/message failure - missing a message
( at 167136 mi )
B1B70-81 (2Cool Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
( at 166925 mi )
B1C82-14 (2F) Headlamp washer relay coil circuit - General electrical failure - circuit short to ground or open
( at 166900 mi )
B1C90-14 (6C) Auxillary driving lamps relay coil circuit - General electrical failure - circuit short to ground or open
( at 166900 mi )
B1C95-15 (2E) Approach lamps circuit - General electrical failure - circuit short to battery or open
( at 166918 mi )
B1D12-15 (2E) Volumetric alarm power circuit - General electrical failure - circuit short to battery or open
( at 166918 mi )
B1D13-15 (6Cool Interior lamps 1 circuit - General electrical failure - circuit short to battery or open
( at 167117 mi )
B1D14-15 (6Cool Interior lamps 2 circuit - General electrical failure - circuit short to battery or open
( at 167826 mi )
B1D17-87 (2F) Siren Circuit - Bus signal/message failure - missing a message
( at 166900 mi )
B1D18-87 (2F) Volumetric sensor circuit - Bus signal/message failure - missing a message
( at 166918 mi )
Engine TDV6
P0405-00 (2D) Exhaust gas recirculation sensor A - circuit low
P140A-00 (2D) Exhaust gas recirculation sensor C - circuit low
Parking Aid
B1B48-96 (6Cool Rear left outer sensor - Component failure - internal failure
Traffic Message
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
Ventilation
B1B65-15 (6C) Left seat heater temperature sensor - General electrical failure - circuit short to battery or open
B1B66-15 (6C) Right seat heater temperature sensor - General electrical failure - circuit short to battery or open
( at 166904 mi )
B1B75-00 (6Cool Front foot-face mode stepper actuator
( at 167827 mi )
B1B76-00 (6Cool Front left air blend stepper actuator
( at 167827 mi )
B1B77-00 (6Cool Front right air blend stepper actuator
( at 167827 mi )
Height Calibration
Module/Sensor/Height calibrations
Service/Test Menu, offering Key Programming, Service Interval Reset, Aux Heater prime and Operation Check, EPB Unjam function, Lift Pump Security Reset, Suspension valve testing, and Transmission Adaptive Reset
It offers Live Values, both in digital, and graph form
The graphs are invaluable for pinpointing intermittent faults, as you can see the specific rise/fall in readings, instead of the digital values
It offers "Safe" CCF Editing
PatGAPinnov wrote:
Just a few little corrections since Mike does have a Pro and not a BT:
-For safety reasons, access to the full CCF list is available upon request only. However, the tested settings are available to all and these cover 99 % of all requirements.
It also offers "Advanced" editing. For 99% of owners, this option will go unused, but it can be made available for anything you want to retro-fit, or enable. This is where the CCF Restore function is invaluable Bow down
-Re-flash wise, the Pro is capable of housing all supported files while the BT does require either updating the tool to a special firmware for the Nav On Move or using the PC based interface for updating the Bluetooth in any other languages then UK English.
For more details on which re-flash are available and the fast lane service, please have a look at the user manual: http://www.gap-diagnostic.com/support/documents.html
ECU Flash screen. All of these Firmware options are free to use. There is a small charge for Firmware not listed in this menu, and is supplied direct from GAP.
The ECU Info tab allows you to see modules which are fitted to the car and what firmware is currently installed. Invaluable if you are having module communication issues
The Save/Restore tab allows you to save your specified height requirements, and change to them in a matter of seconds, as well as the CCF Restore, just in case Wink
Considering a main dealer will generally charge a minimum of £100 for a diagnostic plug in, the IIDTool offers excellent value for money, and while the saving is not huge, its better than nothing Thumbs Up
Post #450835 31st Aug 2015 1:27pm
Cupboard
Having now signed up over on Disco3, I'm wondering how this differs from the BAS plug in doodad. They look very similar, BAS will do remaps via the IID tool but buying direct from BAS is cheaper.
Post #451784 3rd Sep 2015 12:32pm
bell-auto-services
The BAS2 tool only covers engine and related functions and no other modules on the car and is sold primarally as a tuning tool with a remap
IIDTool covers the full car and all its modules. and tuning is sold seperatly here should people want to add it to the IIDTool.
https://secure.bellautoservices.co.uk/stor...nd-tuning/
Post #451795 3rd Sep 2015 1:20pm
Lost for Words
The BAS tool doesn't offer the full diagnostic coverage that the IID does. For the Defender, I'm not sure exactly what the differences are, what with the Defender being a somewhat more simple vehicle compared with other LRs. ABS is one thing, I believe. The IID does also offer the standard functions (i.e. diagnostic stuff, rather than ECU flashing and calibrations) for all covered vehicles. Thumbs Up Visiting from DISCO3.CO.UK
Post #451797 3rd Sep 2015 1:23pm
bell-auto-services
For the Defender the engine functions on both tools are identical.
The IIDTool however does support the ABS live data as an extra currently and at some point we think more will also come onto it like the 10AS alarm and key/plip programming etc etc.
Below are the live value options in the IIDTool for the ABS, some puma engine live values can be seen here also. The 2.4 does differ slightly to the 2.2 for value options.
http://bellautoservices.co.uk/help-faq/bas...live-data/
Post #451858 3rd Sep 2015 3:43pm
Lost for Words
Thanks for that, Pete. Just a little reminder, chaps, that you have until Sunday to decide. Thumbs Up Visiting from DISCO3.CO.UK
Post #452136 4th Sep 2015 10:47am
Cupboard
Thumbs Up
so the IID is a bit more universal and can do a little more on the Defender, but a slightlier pricier option if all you wanted is a remap. So IID probably best for me then. Thanks Smile
I take it they are related then?
Post #452152 4th Sep 2015 11:34am
PatGAPInnov
Site Sponsor
Canada
Whistle
Post #452199 4th Sep 2015 1:43pm
Lost for Words
Last day to sign up. Thumbs Up Visiting from DISCO3.CO.UK
Post #452751 6th Sep 2015 11:39am
Disco_Mikey
As it stands, we have 17 signed up, so the buy will be going ahead
It will close at midnight, so still a few hours to sign up Thumbs Up
Post #452775 6th Sep 2015 1:24pm
