Home > Maintenance & Modifications > No Stop Lights
barbel jim
No Stop Lights
I have done a search but to no avail ........
Started today, when I brake all my sidelights come on !! If I put on the side lights brake lights are permanently on as well!
Guessing its an earthing issue somewhere, and was looking for pointers as to where to start please
Post #451539 2nd Sep 2015 8:26pm
grafty99
It might be worth unplugging the trailer electrics loom, mine had a weird fault where the drivers side indicator came on permanently due to corrosion in the plug Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #451545 2nd Sep 2015 8:33pm
Romadog
bulbs correct way round ???
Post #451550 2nd Sep 2015 8:40pm
barbel jim
Might be a good shout, as she's now semi retired, I havn't towed anything for a while George Ta
@Roma....not changed or altered anything, just drove it
Post #451560 2nd Sep 2015 8:50pm
barbel jim
disconnecting towing socket hasn't worked Big Cry
Post #451583 2nd Sep 2015 9:19pm
Rich broom
My bet is you have a single filament sidelight bulb instead of a twin stop tail.
Sounds like halfords have been at it
Post #451587 2nd Sep 2015 9:21pm
barbel jim
Unless someone's swapped my bulbs, that can't of happened 👍
Post #451597 2nd Sep 2015 9:36pm
grafty99
Too much bass? Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #451612 2nd Sep 2015 10:09pm
barbel jim
could be Rolling with laughter I'll have another prod in the morning supposed to be heading back down your way tomorrow Rolling Eyes
Post #451623 2nd Sep 2015 10:30pm
grafty99
Take the puma Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #451634 2nd Sep 2015 11:00pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Sounds like a short somewhere i.e. bare wire rubbing perhaps. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #451690 3rd Sep 2015 8:29am
dgardel
Italy
check the fuses Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #451691 3rd Sep 2015 8:39am
barbel jim
sorted Thumbs Up
It was an open circuit caused by the 2 terminals touching in the o\s stop/tail bulb holder.
Thanks for all the replies, hope it can help someone else out
George ........... NO You'll hear the purr of the TD5 pass later
Post #451697 3rd Sep 2015 9:11am
I'm thinking an open circuit on the earth connection between the rear lights and the chassis.
If you turn on the sidelights and brake while the sidelights are on, do the lights all go out?
EDIT - my post made simultaneously with the one above.
Post #451701 3rd Sep 2015 9:17am
barbel jim
Cheers Blackwolf, I was hoping you or K9 read this last night Thumbs Up It was quite a simple fix for a change Shocked The symptoms where the exact opposite, ie no lights apply brake = all lights on, and when lights, on brake lights permanently illuminated, apply the brake had no effect. I was thinking broken wire/rubbed through
Post #451715 3rd Sep 2015 9:46am
