Home > Td5 > TD5 Immobiliser Remote Handset
mikeyp
My TD5 only came with 1 x remote handset and 1 x key.
I have had a key cut at local cobbler, but I need another remote handset as the chip inside is needed to disable the immobiliser.
Can order a handset from LR dealer, but my local one wants an hours labour to pair it with the car which seems a bit strong. Whats a fair amount of time for this? I would have thought the job takes no more the 10 mins, so call it 30 mins.
Post #42317 9th Oct 2010 4:41pm
If you get the correct "plipper" thing (there's various ones available from the Rover range, all look the same, but internally work on different frequencies) then it's literally a 2 minute job with a nanocom to match the new plipper to your car.
I can't remember what plipper you need now, i'm sure a google search will come up with it, or give Pete @ Bells or Ian @ IRB a shout, they'll give you the definitive answer.
Post #42324 9th Oct 2010 7:42pm
tasr12
England 2002 Defender 110 Td5 CSW Zambezi Silver
As above and have done a quick search online. The following comes up:
http://www.remotekey.co.uk/land-rover/defe...erallinone
I like the thought of an 'all in one' but £93.98 is a fair whack are there any other recommendations out there from those who have purchased another key and immobiliser for their TD5?
Spare Rover 'plipper' and then hope someone local has a Nanocom?
Thanks. 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD
Post #450699 30th Aug 2015 8:36pm
Swac3
\i used those guys to get a regular fob for mine as it only came with one, 70 quid once you send the programmer back and get your deposit back.
Our local dealer charges 120 quid an hour so even a 30 min slot is almost the cost of a DIY job, god knows what LR charge for a fob,
And yeah basically a 10 min job including reading the instructions and walking out to the car to plug in the programmer. 3 Landrovers
Post #450718 30th Aug 2015 10:53pm
tasr12
Thanks. They may get an order soon!
Can a fob only be programmed by a Nanocom if you get one off EBay or is here another DIY means for those without the box? 2002 110 CSW TD5, Zambezi Silver
Post #450761 31st Aug 2015 8:40am
Ian at IRB do these, mine is faultless and seems to have improved the range a heap.
Post #450763 31st Aug 2015 8:42am
