Home > For Sale & Wanted > [For Sale] Driving light switch and plug - YUG000540LNF
Iain
For sale:
The switch and plug for the driving lights to be set up.
This is the actual parts taken from a Landreiziger driving lamp loom kit, I have a carling switch for the job so do not need this switch. Link to supplier: https://shop.landreiziger.nl/modificatie/m...-laag.html
Still sealed and ready to fit. Any questions, please ask.
£30 inc shipping in the UK, cheque or BACS best, paypal would be plus any fees.
 COTAG 4x4 Response
2015 XS USW Corris Grey on DF MTR's
Post #447307 19th Aug 2015 9:53am
I'll take it please.
Post #447309 19th Aug 2015 9:58am
Iain
Prov sold COTAG 4x4 Response
Post #447310 19th Aug 2015 10:10am
Martin
Site Admin
Dammit, got to be quicker than Matt Twisted Evil  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #447311 19th Aug 2015 10:10am
Lorryman100
I am not 100% sure the Landreiziger switch has not been adapted to work with their loom after I fitted their loom and used the original LR oem switch with no joy. JMTW Wink
Lorryman100 wrote:
Just fitted the Landreiziger kit and all in took me 4 hours ( should have taken me 3 hours Evil or Very Mad ) as I had to remove the LR spot loom first and I like to take my time and do a tidy install.
So all installed, relay inserted and then the fuse. Jumped in the drivers seat and started the Puma and put on the high beams, the Noldens went into high beam but the light bar, nada, nothing. So out with the DMM and found no power at the lightbar connection, ahh I thought I know where the issue may be. Nope wasn't what I thought it was and to save boring you all with the fault finding which after I completed showed no faults found??? It turned out the dash switch you get in the kit is required for the loom to work and I had used the original switch which came with the LR loom so wasted an hour trying to fault find a non existant fault. Embarassed
So in with the new switch and once again started the Puma and switched on the high beams, result the light bar was shining bright, now off to set up the light bar in the dark.
Post #447329 19th Aug 2015 11:19am
Iain
Lorryman, thanks, I did go over and over the genuine light installation instructions and numerous threads on here, they seemed the same. I may be wrong though as first time with this kit and not fitted a genuine one.
Even still if there is a difference sure it can be sorted to work fine in with whatever the vehicle loom set up is. COTAG 4x4 Response
Post #447360 19th Aug 2015 1:03pm
Lorryman100
I'm sure it will work fine. My post was aimed more at if it did not work first time, instead of rechecking the loom where I wasted time on, start at the switch. Thumbs Up
Post #447376 19th Aug 2015 2:05pm
theorangebandit
So is this sold?
Post #450669 30th Aug 2015 6:54pm
Iain
Yes, sold. Apologies. COTAG 4x4 Response
Post #450704 30th Aug 2015 8:51pm
