![]() | Home > Maintenance & Modifications > Later front lights etc onto 200 tdi? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
The Wipac Crystals is a fantastic upgrade which I have done myself which can be found here.
http://www.defender2.net/forum/topic24287.html?highlight=wipac I would highly recommend this upgrade as the amount of light they throw is fantastic- pair it with a up rated loom and you have a very reliable and very good set up without all the hassle (and huge expense) of going down the LED Route. The Td5 grill will fit, the only difference is on the headlight surrounds there will be little vents between the marker light and indicator. This is for the horn which is relocated on a Td5, shouldn't make too much difference it just depends how much you want to keep it looking original - most people wont notice. With regards to changing the bulb holders, you can get genuine ones for not much money still from Land Rover which work fine which will be a good direct replacement. The alternative is you would have to chop off your bullet connectors and find the appropriate connector type and then buy a new set of Td5 ones to match which may or may not be cheaper. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
http://www.defender2.net/forum/topic39575.html
![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
There are a few conversion routes...
Econoseal connectors if you go DIY: http://polevolt.co.uk/acatalog/Econoseal_Connectors.html (For further information, the adapter loom for the 3 pin rear tail/brake lamp is STC4637. �22 LR or �5-6 aftermarket) ![]() ![]() Last edited by Martin on 26th Aug 2015 1:33pm. Edited 1 time in total |
Had no idea of that! The more you know ![]() Self confessed mileage hunter ![]() |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1885 ![]() ![]() |
Such good news, thanks very much guys and pleased that it appears I have also facilitated some further education!
RRUK, I had seen that but as I do not need rear rear fog and reversing and will be looking for crystal headlights it doesn't appear to make much sense and I had assumed you would not want to split? |
Fair enough chap, no problem 2016 D4 HSE
