Home > Maintenance & Modifications > Puma bonnet sound deadening...
YOLO110
Australia
Has anyone done this?
I have spent quite some time searching for an under bonnet sound deadening 'kit' for the Puma but cannot find much aside from a bit of Dynamat...
I think the problem is with the bonnet shut, there is less than 1cm clearance between the top of the engine and the forward bonnet 'bulge', so I am guessing whatever was used would be in contact with the engine... heat and vibration transfer issues?
Is there a solution? I think most of the Puma noise comes from the engine top end!
Cheers. Smile YOLO... You Only Live Once...
Post #448890 24th Aug 2015 11:20pm
Roy5695
There's a product called fatmat that I've recently seen fitted to a puma bonnet. I'm waiting on a price before I order any though they as I want to do the whole double cab.
The guy that fitted it said it was promising though...
Post #448893 24th Aug 2015 11:40pm
Why don't you want to use Dynamat (or Skinz, etc etc) ?
Post #448904 25th Aug 2015 6:13am
Venomator
@YOLO110
Mamba has been done in Dynamat Pete (before my time!)... Thumbs Up
Do not see any contact issues at all... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #448906 25th Aug 2015 6:29am
Roy5695
All down to cost and the way it looks, I don't really like the big silver logos or shiny tops. Fatmat is all black and supposedly just as good... But the proof will be in the pudding...
Post #448937 25th Aug 2015 7:53am
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I don't personally think you need any proprietary system. Here's what I did:
http://www.defender2.net/forum/topic38290.html
HTH
Post #448939 25th Aug 2015 7:58am
YOLO110
Australia
Re: @YOLO110
Cheers Rog!
Yup, the Dynamite does not contact... but I did not know if it would be effective! Clearly it is!
Plus the other stuff too!
Another project on the way then!!! Cool YOLO... You Only Live Once...
Post #448957 25th Aug 2015 8:59am
K9F
Have you seen Barney's thread. With a sound reduction of only 2dB it's not worth the effort surely? Save your money for something worthwhile.
Barney12 wrote:
So pre-mod the readings were:
Outside (30cm from grill, level with bonnet): 67 dB
Inside (30cm from dash, level with top): 57 dB
So what are the results of the re-test:
Outside (30cm from grill, level with bonnet): 66 dB
Inside (30cm from dash, level with top): 55 dB
Hmmm so hardly much to write home about but I'm convinced (could just be the heat effecting my brain) the sound is "deader". Guess I should have taken it on a run for a proper sound test.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #448959 25th Aug 2015 9:09am
jimbob7
I used 10mm latex backed felt on my bonnet. Pov.spec,ftw. 2006, 110,TD5.
Post #449010 25th Aug 2015 11:45am
gilarion
Noise Killer does a full Puma bonnet sound kit. I have fitted one and all parts fit well.
http://www.nkgroup.co.uk/product/full-land...ofing-kit/
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #449054 25th Aug 2015 2:05pm
Grenadier
Mine comes with some deadening already, factory fit. 'Comfort Pack' I think. But as K9F alludes to, I wonder what difference sound deadening will make to a Puma engine, they're pretty quiet already. I would have thought the bulk of the noise in a Puma Defender would come from theroof, footwell, doors, rear wheel arches and middle/rear floor tub. I would suspect getting those sorted would have a far greater impact than engine noise. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #449077 25th Aug 2015 3:08pm
K9F
There are two threads running on the same subject....
Cut and paste from the other one....
K9F wrote:
Be aware that fitting bonnet insulation can actually increase cab noise apparently. Also the phone applications for noise measuring are only accurate when static.
http://www.defender2.net/forum/topic20069.html?highlight=db
Post #449091 25th Aug 2015 3:34pm
Barney12
Genadier is right that its a combination of sound deadening all panels that really makes the difference.
IMHO we'll never achieve anything stunning due to:
1. The front windscreen which is a similar thickness to my greenhouse
2. Noise transmitted from the bulkhead which is all but impossible to soundproof effectively.
One option is simply to turn the radio up Mr. Green
If I ever go to fully reassemble the rear of my 90 (rear seats are still at the trimmers waiting for the full leather treatment) I'll re-meassure the noise with my trusty sound meter.
Post #449117 25th Aug 2015 4:31pm
Barney12
P.S. Our Disco 3 is much quieter
P.P.S. Our RAV4 is so quiet that on idle I often think it has stalled!!!
Post #449119 25th Aug 2015 4:33pm
SGH
I fully treated with Dynamat and Dynaliner my Defender 130 but did not get around to the bonnet until recently. TBH I have not noticed any difference since doing it. Sad 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #449122 25th Aug 2015 4:38pm
