Home > Puma (Tdci) > Charging fault? |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
Hi!
I am stuck in Almaty, Kazachstan with faulty clutch slave cylinder. Today it was replaced with new one at LR dealer but just after leaving I have realised my charging voltage occassionally dropping to 12v,illuminating the battery dash light. Is it the generator fault or they may screw something while changng the slave cylinder? Its 8pm here, tomorrow they continue. Any hints? Janusz Janusz www.yahodeville.com |
23rd Aug 2015 1:53pm |
I presume they may have isolated the battery whilst working on it? Check the connections. If you go through life with your head in the sand....all people will see is an ar5e!!
23rd Aug 2015 5:00pm |
Thank you for the hints. In the meantime I have swapped the generator but the problem persists.
Today I have crossed to Kyrgystan and noticed the voltage drops only on bumps, sometimes causing the stereo to restart. Jumped under the vehicle, ground cable seems to be firmly fixed to the gearbox. Where shall I look next? Cheers! Janusz www.yahodeville.com |
25th Aug 2015 3:50pm |
Battery connectors, starter motor and alternator connections would be my next ports of call. If you go through life with your head in the sand....all people will see is an ar5e!!
25th Aug 2015 4:28pm |
Thanks again. I will check it. How serious the problem is? Can I continue for e.g. next 1000 km losing charge from time to time? Yesterday I did 300 km, the battery light went on only once, I can see on IBS both batteries are fully charged.
26th Aug 2015 3:24am |
26th Aug 2015 3:30am |
Fixed. Fuel line bracket was rubbing power cables.
Cheers from Uzbekistan! Janusz www.yahodeville.com |
4th Sep 2015 7:59am |
