![]() | Home > Wheels & Tyres > Law on tyres/wheels protruding from the arch. |
Thought this may be of some use, the law on how much your wheels/tyres can protrude from your arches.
![]() Link to full regs: http://eur-lex.europa.eu/LexUriServ/LexUri...49:EN:HTML Council Directive 78/549/EEC of 12 June 1978 on the approximation of the laws of the Member States relating to the wheel guards of motor vehicles 2.1.2. The rear of the wheel guards must not terminate above a horizontal plane 150 mm above the axis of rotation of the wheels (as measured at the wheel centres) and furthermore the intersection of the edge of the wheel guard with this plane (point A, figure 1) must lie outside the median longitudinal plane of the tyre, or in the case of twin wheels the median longitudinal plane of the outermost tyre. 2.1.3. The contour and location of the wheel guards shall be such that they are as close to the tyre as possible ; and in particular within the part formed by the radial planes referred to in 2.1.1, they shall satisfy the following requirements: 2.1.3.1. the projection - situated in the vertical plane of the tyre axis - of the depth (p) of the outer edge of the wheel guards, measured in the vertical longitudinal plane passing through the centre of the tyre, must be at least 30 mm. This depth (p) may be reduced progressively to zero at the radial planes specified in 2.1.1; In short, the wheel must NOT protrude more than 30mm past the edge of the mudguard. It's also in the MOT regs (d) wheels, if there are no pointed or sharp features which projects beyond the external plane of the wheel rim, no wing nuts are fitted and there are no projections beyond the vehicle body plan form apart from tyres and wheel discs, (including central wheel securing nuts) if the latter have a radius of curvature of not less than 30mm and do not project by more than 30mm beyond the vehicle body plan form ; ![]() Last edited by fekete on 10th Nov 2010 6:31pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17712 ![]() ![]() ![]() |
Very interesting, but the link doesn't seem to be working!
Here you go
![]() http://eur-lex.europa.eu/LexUriServ/LexUri...49:EN:HTML NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
fekete, fitting these would probably make the tyres you have legal in the sense they will be conforming with this law? Or am I reading it wrong
Cheers Karl, what arches did you get? I ask because I'm in the process of getting some 305's
Hi Brian i got a set of pacer wheel arch spats from Canada when i was over there they are about 1-3/4" ill get a pic up in a bit
![]() Last edited by fekete on 30th Dec 2010 12:15pm. Edited 2 times in total |
Here you go Brian...You can get them in about 4 different sizes
http://www.truckcustomizers.com/products/p...lares.html But i got mine from here http://www.national4wdonline.com/cart.php NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Me like
The problem with the terrafirmas is you have to drill the bodywork
![]() ![]() ![]() there just staying in the back in case i get stopped...I've been past lots of coppers and they have just looked but there was one that pulled me he was ok but told me they were illegal and asked me to sort it out i think he just wanted a closer look at the landy ![]() |
Here is a pic of some fitted but they have removed the original spats but it will give you an idea how they will sit on the original spat and still keep the shape of the wheel arch
![]() Click image to enlarge NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
That's what I would do, remove the originals carefully and fit the replacements in lieu of the originals
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
guess who
RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear |
Some fat bloke in a mask with man boobs
