Home > Maintenance & Modifications > Brendan
BigMike
Brendan
Are you about? Saw your (excellent) post on the lro forum re jump start cables and anderson connectors etc.
Have you thought about doing a "kit"? ie 3 metres of suitably rated cabling, Andersons and clips, all crimping done, cable for battery through seat box to anderson?
In case anyone is scratching their head thinking whats this about? you can read it here
http://www.lro.com/forum3/viewtopic.php?f=...p;p=543949
Post #44811 9th Nov 2010 8:45pm
leeds
Thanks Mike Embarassed
But have a look HERE on Defender2. Razz
Note the dates of posting. Must admit I intend expanding/tidying that post up and doing it as an information leaflet.
A lot of information on Anderson connectors can be found HERE
Trying to tread carefully here lets say we have siamese/twinned cable which helps keeps jump leads neat and tidy and can do leads to peoples own specifications. We do make 3.5m and 5m jump leads etc.
Information on cable we use can be found HERE
Can't/won't try to compete on prices with many of the ebay type suppliers.
I believe one of the LR mags (LRW) are doing an article on Anderson connectors in the near future.
Same magazine is apparently doing an overland feature in their February issue
Brendan
Post #44818 9th Nov 2010 9:35pm
BigMike
ah hadnt seen that.
I want something like this and frankly can't be bothered to make it, and not interested in ebay listings a number of which may have questionable equipment. what diameter cable are you using?
Post #44819 9th Nov 2010 9:42pm
leeds
The cable we use is twin 35mm2 cable made from 1083 x 0.2mm copper strands per core. The higher the number of copper strands/smaller the diameter of individual strands the more flexible the cable is. The cable is rated at a continuos 240 amps or 500 amps on a 30% duty cycle.
As a rough rule of thumb a copper cable can carry 7 - 8 amps/mm2
Hope that is of some help
Brendan
Post #44898 10th Nov 2010 6:23pm
