Home > Td5 > Emissions/Smoking
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Emissions/Smoking
Hello Team!
So, my TD5 failed it's MOT on friday thanks to emissions, scoring average of just over 5.
After a weekend of flogging, ragging and two tanks of V Power it's passed but barely, averaging 2.85 and it was pretty smokey having done it.
Quick summary: 2004 TD5, 75k miles, EGR blank and twisted Stage One map, K&N filter and Safari snorkel but otherwise completely standard. Just been serviced, had new MAF sensor as well (the old one wasn't functioning). Does about 6k a year with em some long trips in there as well and it's not driven too gently as i enjoy the power. Doesn't use any oil (or non-noticeably) and drives well I think. gets decent diesel, very rarely supermarket.
Anyone got any ideas what to go looking for or what could be wrong? I'm concerned it's all a little high emissions wise and there is something else more sinister going on rather than just a build up of soot.
Thanks Smile
Post #437493 13th Jul 2015 5:15pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Have you tried diesel additive such as redex?
It sounds like the injectors are carboned up.
Worth having a look for diesel additive, I think there is more powerful stuff than redex available, but might be trade only.
My TD5 has 172k and sailed through its MOT, doesn't smoke and doesn't use oil.
Post #437556 13th Jul 2015 9:35pm
mk1collector
Has it been serviced recently? Ray
My build thread
Post #437561 13th Jul 2015 9:50pm
Northernremedy
Hey!
Yes literally serviced about three weeks ago, new MAF fitted. Re the injector cleaning, wondered about that but currently running few tanks of v-power through it, been advised probably best not to put both in at once as the v-power has additives in
Post #437599 14th Jul 2015 7:44am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Try cleaning the MAP sensor, the one on the inlet manifold, easy to do, remove it and give it a good clean with carb cleaner or similar, make sure your air filter is clean too. If that fails have a look at the turbo and inter cooler hoses, one might have split or collapsed inside.
Post #437602 14th Jul 2015 8:05am
Northernremedy
Thanks for that. Yes I'll whip out the map and see what it looks like. Maybe some silicon hoses be no bad idea
Post #437618 14th Jul 2015 9:27am
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Try this apparently what the dealers use.
http://www.forteuk.co.uk/product-detail/47...or-Cleaner
you can get it on ebay in a double pack turbo cleaner and injector cleaner.
my guy who maintains mine fills up the fuel filter with it and runs it neat through it for quick blast but it works well just in a tank of fuel.
Stopped mine smoking a lot.
Post #437630 14th Jul 2015 10:23am
Hunter75
United Kingdom 2006 Defender 90 Td5 CSW Cairns Blue
Back to get the re map tweaked Mate and it will not be long till the egr will have to be present and working to pass MOT
There going to plug in all our cars soon
Mines still in my shed... Get some Fuel System cleaner in there it will not harm it I've ran
Millers and v power at the same time on a 200 mile run..
Is the car eating oil mite be injector seals ?
Post #447604 20th Aug 2015 7:44am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
TD5 EGR is a mechanical valve. How is a diagnostic computer going to tell you it's working Whistle
To the OP, check the boost pipe work for splits/leaks, as well as the intercooler. And oil ingress into the injector loom
Failing that, you may need it plugged in to check for any faults, and make sure all sensors are reading OK
Thumbs Up
Post #447619 20th Aug 2015 8:03am
