![]() | Home > Maintenance & Modifications > Anyone Fitted JW Speaker Evo2 with DRL Integrated |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
saltydog Member Since: 13 Mar 2012 Location: Aberdeenshire Posts: 91 ![]() ![]() |
Looks even better than I thought LR Defender 110 XS Utility Wagon
LR Discovery 2.0 Sport HSE LR Discovery 4 Landmark |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
Looks immense - I have been mulling over these for a while now - but now i'm going to have to get them, and the lazers!
Just the wiring up that worries me... spent all weekend wiring up the 13 pin electrics - first time under a vehicle and found that ok until i came to the battery - scares the ![]() |
DRL are easy buy from Tim at the Mobile centre hell knock up a Plug and play side light feed then all you need is a 12v ignition fed live easiest IMHO is the heater blower under the hood NS bulkhead
What about the light performance on dipped and full beam, i see on dipped different bulbs are lit compared to the standsrd evo 2 LR Defender 110 XS Utility Wagon
Td5 Member Since: 29 Jun 2015 Location: Finland Posts: 53 ![]() ![]() ![]() |
Would anybody have a wiring diagram how to wire these so that the tail lights come also on with DLR?
Also I bought the wiring loom from Tim, but cant figure out what the extra connectors are for. There lamps itself has a 3-wire connector where 2-wires are connected, one red for FP and a blue for DLR. The wiring look has this 3-wire connector all 3 connected, there is 2 black wires connected where there is no wire in lamp connector. There is 2 black wires that go each to a 2-wire connector, one male, one female. The red FP wire is also split and goes to these 2-wire connectors. I don't plan to use the FP light as Defender already have the FP lights, but I would like to have the DLR coming on when I start the car and also the tail lights. Also if I switch the lights on from the light switch, I would like to have just the original FP and tail lights on. Switching the low/high beam from the light switch, I would like to have the DLR turned off. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
