Home > Technical > Oops - delaminated inter cooler hose? |
As a/consequence pump and fan cut in and out it can cause a stutter due to the extra load
16th Aug 2015 1:06pm |
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 |
Cheers for the pointer.....Only started about 300 miles in......
16th Aug 2015 2:30pm |
Delaminated hose?
Just having a good check over the 110 and this hose looks very suspect.....this is the hose on right hand (drivers side) looks like an outer sheath has split over the bend? Can clearly see a split and separation in a short outer sleeve...over the spiral, the rest of hose looks ok but can't see below this part. Could be AC is distracting from real issue? Question is whether we need to get hose replaced here in France (could be a saga) Last edited by LittleFoot on 17th Aug 2015 7:33am. Edited 1 time in total |
16th Aug 2015 6:04pm |
Don't think that's a a/c pipe . But only looking on my phone
16th Aug 2015 6:37pm |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 |
The split hose seems be turbo to intercooler hose (Which is kind of a weird hose for an intercooler hose) Seems to be standard ducting hose. If this is the case I would definitely recommend immediate replacement, as this is after the airfilter you rub the risk of the engine taking in all kinds of crap.
This would definitely explain your issue as you miss pretty much all turbo pressure. Hose part number: PNH500670 |
19th Aug 2015 12:06pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
the one with the metal spiral around it is definitely the intercooler hose... would need immediate replacement if it is split...
19th Aug 2015 3:21pm |
Thanks all - sent pics to dealers and they recommended it's ok to drive as the hose is a multilayer hose with sheath over the reinforcing spiral...and as no evident loss of power, excessive whistling or fault lights on.
Hope it lasts till we get back tomorrow. LR assist back from France would be a pain! Bloody LR hoses! |
25th Aug 2015 8:40am |
Well, happy to say we made it home safely under our own steam, after 1500 miles.
Just waiting for Dealer to get it in and check it over. Thanks for all the advice. |
29th Aug 2015 12:43pm |
