Home > Puma (Tdci) > Dci, not tdci anymore. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5663 |
I will let the picture tell the story.
Click image to enlarge |
15th Aug 2015 8:38pm |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 |
Ouch
15th Aug 2015 8:45pm |
Nakatanenga gasket? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
15th Aug 2015 8:50pm |
Yep was running a Nak gasket. Why the question? Any thoughts?
Andy |
15th Aug 2015 9:33pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Upps!
Great failure Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
15th Aug 2015 9:36pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1641 |
Ouch WHY would a gasket cause that failure? Are they a variable thickness?? YOLO... You Only Live Once... |
15th Aug 2015 10:18pm |
no, but just for understand. Is your var tuned? Tuner? It's strange indeed the Nakata gasket is wider and softer.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
16th Aug 2015 8:20am |
I am only speculating but would have thought either the unit had been subject to impact damage, it had a flaw in the material or it had been overtorqued, maybe one or more of the preceding to cause such catastrophic failure perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
16th Aug 2015 8:26am |
It was on tight, well as tight as you can get M8 nuts with a ring spanner.
16th Aug 2015 8:33am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Would that not point towards excessive EGT? 2002 90 Td5 Station Wagon
16th Aug 2015 8:59am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
I am of this school of thinking too. |
16th Aug 2015 10:28am |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 |
That really is odd. I'd guess the combination of a thicker than usual gasket some overtorque of the bolts and lots of extreme thermal cycles.
Not a good sight. Jonno |
16th Aug 2015 9:01pm |
All fixed now, so will see how things go.
16th Aug 2015 9:27pm |
What did you manage to do in the end?
16th Aug 2015 10:24pm |
