Home > Puma (Tdci) > Reverse gear spring? |
Td5 Member Since: 29 Jun 2015 Location: Finland Posts: 53 |
When engaging reverse in my 07 Puma, the spring is very stiff and it require some amount
of force to put gearbox in reverse. My car is left hand drive. After I get my other car out from my garage I will do the clutch and gearbox output shaft and would like to fix this also. Is the reverse spring accessible without tearing transmission apart? (apologize if I don't explain this clearly enough) Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
14th Aug 2015 12:49pm |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
Hi,
I can t help but I agree ! I have some problems with my right arm, I have tout use my left arm also tout engage the reverse ! Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
15th Aug 2015 5:42am |
