Home > Technical > Aircon grill surround bolt size?
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Hi does anybody know the size and length of the 2 capped bolts in the side of the aircon grill surround as mine are rusty and I want to replace with stainless. Thanks in advance Thumbs Up
Post #445287 11th Aug 2015 10:33pm
munch90
Arent they a big self tapper screw
Post #445291 11th Aug 2015 10:37pm
RRUK
Yes they are. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #445295 11th Aug 2015 10:43pm
Oakseywick
What size?
Post #445299 11th Aug 2015 10:49pm
munch90
Thought so , maybe someone has replaced them with normal headed self tapper instead of big phillps headed
Post #445300 11th Aug 2015 10:51pm
munch90
I would say about 6mm so in a screw think they might be 6.3mm self tapper ( sorry not 100% as never measured them )
Post #445301 11th Aug 2015 10:53pm
Oakseywick
Just checked with a torch they are hex bolt heads with flange which bolt into a captive nut on a bracket inside the grill surround one on left side and one on the right?
Post #445304 11th Aug 2015 10:56pm
munch90
Pretty sure ive never seen a normal threaded bolt , only self tappers , guessing someone has changed them before
Post #445308 11th Aug 2015 11:00pm
discomog
Just recently replaced mine with A2 stainless posidrive pan head self tappers 6.3mm dia thread, 20mm long.
Post #445323 11th Aug 2015 11:50pm
munch90
^^^^ yep sounds right Thumbs Up
Post #445347 12th Aug 2015 6:37am
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I had the same issue. My local Indy had packs of the pozi's from Britpart (insert expletives about quality etc) for a couple of quid:
Same as here (first result on Google):
http://www.rimmerbros.co.uk/Item--i-LL1548BP
Strangely this is supposed to be a set for the grill but actually contains 8 of the pozi sized mentioned above. On my Puma grill these are only for the two side points as being discussed. I then have 4 smaller pozi's which run along the top edge.
Not sure if the above helps but there you go Smile
Post #445351 12th Aug 2015 7:39am
