Home > Maintenance & Modifications > Clutch rattle
90def
2011 Defender 90 Puma 2.4 HT Epsom Green
Clutch rattle
I've got tapping type rattle from the clutch . it goes when I put my foot on the clutch ... What is it and is it a problem cheers Phil ..it's a 5 year old puma done 47k
Post #445214 11th Aug 2015 5:40pm
Probably clutch springs. That's my guess anyway.
Post #445216 11th Aug 2015 5:51pm
bear100
Turn the engine off in neutral and listen to the noise, then do the same with the clutch in its probably a lot less noise. If so its the clutch springs, mine has the same and has been for the last 10 months, just an annoying noise really 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #445233 11th Aug 2015 7:04pm
90def
Cheers for the replys glad its not a new clutch thanks Phil
Post #445243 11th Aug 2015 7:34pm
nidge n
I've had exactly the same issue for months. Not got any worse than the day it crept into my life. I was thinking springs or could it be imput shaft bearing?
Post #445261 11th Aug 2015 8:30pm
munch90
springs are part of clutch , so yes all new clutch needed
Post #445268 11th Aug 2015 8:42pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Replace clutch ASAP!
Just done mine, just in time too, 2 springs were literally ready to pop out, and they started to chew up the clutch plate which could have caused untold damage if it had of let go!
Don't ignore this noise...... Whistle 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #445289 11th Aug 2015 9:35pm
Dora
Yep, mine too.. Just had it and the Ashcroft input shaft conversion done at 89k. springs about to pop and shaft knackered!
Post #445293 11th Aug 2015 9:42pm
Other way round - clutch in, noise. Clutch out, no noise.
Clutch in = pedal up. Clutch out = pedal down. A widespread misunderstanding of clutch terminology!
Eventually the springs will fall out and it will be much more than just an annoying noise.
Post #445294 11th Aug 2015 9:43pm
munch90
To most people including most car trade , if you said let the clutch out it would mean take your foot off pedal
so clutch out would mean pedal up
Post #445296 11th Aug 2015 9:47pm
Like I say, it has become a very widespread (and to me rather incomprehensible) misunderstanding. You let a clutch in to take up drive, you throw a clutch out to disconnect the drive. It has always been thus, since about 1873.
Post #445302 11th Aug 2015 9:55pm
munch90
i know what mean , but most will see it otherway round
Post #445312 11th Aug 2015 10:06pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Blackwolf- now that is really interesting! Probably not much use since we all seem to be dyslectic in regard to the use of the terminology. I had never thought of it the way you put it but you are quite correct!
Post #445326 11th Aug 2015 11:09pm
The same is true of gears - "in gear" = drive, "out of gear" = no drive. Less confusion with that though.
Post #445329 11th Aug 2015 11:19pm
