![]() | Home > Puma (Tdci) > Defender Puma 2.2 over fuelling |
rover Member Since: 26 May 2012 Location: Yorkshire Posts: 150 ![]() ![]() |
Get rid, there are so many great 4x4 for sale in South Africa that are not available in the UK, get yourself a land cruiser series 70.
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Could well have been caused by the oil pump fault. Check your chassis number isn't in the dodgy batch.
Robert D Member Since: 04 Jan 2014 Location: Johannesburg Posts: 2 ![]() ![]() ![]() |
LD did replace the motor however the vehicle is still problematic.
It was pointed out to me that the motor failed due to over fuelling and not due to a loss of oil as originally speculated. According to my understanding over fuelling is used to explain a condition during which too much fuel is injected for the amount of air available and normally results in black smoke and abnormally high EGT's. The only type of "overfuelling" which can result in engine seizure without due up-front warning ( which was the case ) is when an injector or injectors fail catastrophically. This will then lead to cylinder washing as well as crown flaming which will cause piston skirt seizure. The biggest cause of such sudden injector failure is apparently due to the presence of water or sticky injector nozzles - this causes the complete injector tip to fail resulting in a constant stream of diesel being pumped into the engine. As the injectors were not replaced during the rebuild I am somewhat concerned that the same fault can reoccur. ![]() |
LR diagnostics to my mind leaves a lot to be desired.
8loodi useless. the drivel I was fed when my drivers door lock was on it's was out was nothing short of unbelievable. I could only stand there speechless with a dropped lower jaw. guess what a few weeks later it packed up completely .....oh back to the same problem again. the defender is a brilliant concept in so many ways but so poorly executed / follow up service beggars belief. I've said it several times before - the defender should be turned into a kit car where by individuals can assemble them with the care they deserve and with a choice of engines, interiors, wheels etc rather than having to do all this after market and rebuild them to resolve the poor assembly process. |
