Home > In Car Electronics > Pioneer on-screen keyboard not working |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
Contact a manufacturer authorised repairer, otherwise if you play with it it'll probably get locked and need this doing anyway.
They usually check the serial number do some electronics and give you a new code and your good to go. Mind you, if it has done what you describe I'd call it a design fault.... |
9th Aug 2015 5:22pm |
JellyBean Member Since: 02 Mar 2015 Location: Suffolk Posts: 142 |
Thanks, Steve. I'll do exactly that. Just wondered if anyone had come across the problem before.
9th Aug 2015 6:22pm |
Might be worth checking if your under warranty or not too? Depends on the docs you had with it and how long you've had it for though.
An authorised dealer worth their salt should know exactly what to do with it or failing that have contacts to sort it out. Chances are it won't cost you much at all unless there is actually something wrong which I doubt. |
9th Aug 2015 8:00pm |
Steve - now all sorted via warranty and service centre. Just thought I'd let you know and say thanks for support.
18th Aug 2015 4:52pm |
Excellent news! You are welcome.
Did they mention what it was in the end or just replaced? |
18th Aug 2015 4:56pm |
They replaced the entire unit - report sheet mentioned failed touchscreen, digitiser, etc and several other faults. But they are history now ....
18th Aug 2015 5:19pm |
