Home > Tdi > Where has my coolant gone?
What to top up very low 200Tdi coolant with?
Kentish Tap Water
66%
 66%  [6]
Boiled Tap Water
0%
 0%  [0]
Mysterious Carrefor coolant?
33%
 33%  [3]
Total Votes: 9
Page 2 of 4 <1234>
shaggydog
Had a bit more of a poke around today.
There are no visible signs of leaks on the engine at all (which for a 200Tdi is a miracle!)
No steam from exhaust
No oil contamination
No bubbles in expansion tank (other than coming through from the radiator when agitating hoses)
No signs of wetness or residue around any joints or p-gasket.
Expansion tank is pressurising.
No misting on the windscreen or smell of coolant from the heater blowers.
No chuffing from oil filler or expansion tank.
All I can think of is ether a crack in the head which is only opening up under turbo pressure or when hot, filler cap is week and letting steam escape (though no residue present or steam visible) or head gasket has gone slightly but not enough to cause any contamination.
What tests can I do?
Any suggestions? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #443490 5th Aug 2015 6:57pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Check the P seal behind water pump pretty common place to leak, quite hard to see.
 Original Member Pie n Pea Club.
110 HCPU Tipper
Post #443492 5th Aug 2015 7:02pm
shaggydog
I have checked and nice and tight and dry as it was done in 2012 with timing belt. Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443493 5th Aug 2015 7:05pm
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Fill it back up and see if it goes down again to start with..
Dump some radweld and do the same again.
Go to a garage and gave the cooling system pressure tested maybe? My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #443494 5th Aug 2015 7:05pm
shaggydog
Did 50 miles to work and back today and its not moved enough to notice.
I don't want to put any rad weld in it as I have never heard anyone use it successfully.
I'm enquiring with local garages to find if they can pressure test it Thumbs Up
Are there any home kits or tests I can do? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443499 5th Aug 2015 7:15pm
Browny90
When I worked for scania trucks I modified a header tank cap with a tyre valve (drilled a hole and fitted a normal tyre valve with some tiger seal) not perfect but worked for me, if you do it, maybe fit a small hose and guage? And don't put too much pressure in.
You might be lucky and hear a leak or the pressure might drop quickly?
Like I said before, it may have been a void that's now been filled.. I would give it more time and see if it goes down over a couple of hundred miles. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #443503 5th Aug 2015 7:34pm
munch90
Test to a MAXIMUM OF 15PSI
Post #443506 5th Aug 2015 7:40pm
Browny90
^^^^^^^ What he said! ^^^^^^ Thumbs Up My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #443507 5th Aug 2015 7:42pm
shaggydog
Haven't been able to work on it this week as it has been a bit manic.
Checked the level this morning (having been topped up on Tuesday) and it had dropped about an inch.
I'm at a loss its so weird, everything suggests it is leaking but there are no leaks!
Its having some tests done tomorrow otherwise its looks like its head off time Sad Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443989 7th Aug 2015 12:27pm
shaggydog
Also, possibly silly question.
On a 200tdi, should the radiator top cap have liquid all the way up to the top of the radiator?
Reason being there always seems to be about an inch gap when everything settles down?
Should it always be full as theoretically the radiator is lower than the level of the expansion tank? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443990 7th Aug 2015 12:29pm
munch90
should be roughly full , check small bleed pipe is free , small pipe comes from top of engine and top of rad then to header tank
take small pipe off make sure pipe is free + check the pipe on the rad
not uncommon for the small pipe to block and will cause strange things to happen
Post #443998 7th Aug 2015 1:25pm
shaggydog
I will take it off tomorrow and give it a blow through Smile Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #444128 7th Aug 2015 8:33pm
munch90
Check the metal end pipes too
Post #444130 7th Aug 2015 8:37pm
shaggydog
Metal end pipes?
The heater return ones? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #444133 7th Aug 2015 8:44pm
munch90
No the bits the small pipe pushes on to , as thats the smallest part one on the rad , one on top of engine , one on header tank
Post #444142 7th Aug 2015 9:12pm
Page 2 of 4 <1234>
