Home > Puma (Tdci) > Rubber vs carpet floor mats |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Go for rubber as it will leak water and the carpets will be constantly wet
3rd Nov 2010 10:02pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
The Bodyshop manger of my local LR dealer once told me that carpets in Defenders were the worst thing ever... YES, because i had mine in 8 times for water leaks and never gave up until it was dry as a bone. I have a loan Defender for a week and it has only rubber flooring and you can't hear yourself fart it is that noisier. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
4th Nov 2010 1:13am |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
been running mine without the floor carpets and had the rubber mats in due to water ingress with no noticable difference, i think the carpet on the bulkhead and seat box is what makes all the difference.
4th Nov 2010 7:40am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
we have both in ours 2.4 90 XS
4th Nov 2010 8:12am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
4th Nov 2010 8:48am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
carpets rubbish. It stains and also if you get and hay ect in there that's it bye bye carpet Rubber wins every time
4th Nov 2010 10:36am |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Rubber mats all the way that was one of the things that I love from my Defender.
Easy to clean in special after a winter forest work (lot of mud). By the way, well no other option here, all Defenders comming with rubber mats Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
4th Nov 2010 12:46pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Whats all this 'rubber mats/carpets' nonsense?
Im happy with my bare metal floor, covered in 3 years worth of Mcdonalds wrappers, stale chips and bogeys! |
4th Nov 2010 1:19pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
The rubber mats in mine have pretty much worn through to the metal! Only done 24k and I don't even own any high heel shoes! T'sheesh!
4th Nov 2010 3:58pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Currently running on carpet with rubber mats onto. Russell
2011MY 110 XS USW Black |
4th Nov 2010 4:39pm |
i have carpet with rubber mats ontop.
the only comment i would add it why on earth did land rover cut the middle row rubber mat in half ? on my td5 it was one long piece of rubber, on the puma there is a join in the middle ... there must be a reason - escapes me I've not had any leaks either .. so the inside is bone dry |
4th Nov 2010 6:07pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
carpet is a disaster if you do any wet offroad work. the door seals leak in deep water as does the battery box and the drivers seat box so they need waterproofing. once the carpet gets wet thats it, takes weeks to dry and stinks. I never really understood why landrover didnt just rubberise the whole footwells area and put bungs in so you could hose it out then let out the water.
4th Nov 2010 6:47pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8025 |
carpet under the rubber mats.
carpet works well to keep the noise down but as mention takes a while to dry out. its better to remove it to dry it. rubber mats you can pick up and shake the crap out of. for me the combination works well. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Nov 2010 7:22pm |
devnull Member Since: 29 Mar 2010 Location: Poland Posts: 18 |
Thank you all for replies. Yesterday I drove a rubber finished one, now I know it definitely needs soundproofing especially at the load space. My Classic isn’t watertight so I’m aware of the cons of having a carpet on the floor.
Peter |
4th Nov 2010 9:16pm |
