Home > Tdi > Where has my coolant gone?
What to top up very low 200Tdi coolant with?
Kentish Tap Water
66%
 66%  [6]
Boiled Tap Water
0%
 0%  [0]
Mysterious Carrefor coolant?
33%
 33%  [3]
Total Votes: 9
Page 1 of 4 1234>
shaggydog
Hi guys,
Following on from my hot and cold Tdi thread.....
I was doing a quick check around under the bonnet tonight and found that my coolant bottle had a dribble left in it Big Cry
Everywhere is closed and I don't have any coolant to top it up.
As a short term fix to get me to work tomorrow and then back via Halfords what is best?
1. Southern Waters Best Kentish Tap Water
2. Boiled the above
3. Some carrefour screen wash from 3 years ago which may be the wrong type
Long term, I can't figure out where the water has gone as there are no leaks on the outside of the vehicle, which ether means its the heater matrix maybe?
Or its worst case scenario its the head gasket Big Cry
Its not making clouds of white smoke or making any bubbles through the coolant tank, the oil is nice and clean.
Where has it gone?
Immediately my problem is how to get to work so what can I top it up with? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #443195 4th Aug 2015 9:14pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I know it's not a tdi, but my Td5 lost water, usually a header tank full every week.
I ran it like this for quite a while, same as you no visible leaks, no smell of coolant, no visible signs from exhaust, I looked everywhere Big Cry
I did a sniffer test to see if it was gasket related, all clear, nothing!
In the end I took the head off, it had gone between 4-5, new gasket fitted, water loss fixed! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #443203 4th Aug 2015 9:26pm
shaggydog
Big Cry
She is going in for her very heavy service next week, would a garage be able to diagnose without taking the head off? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443210 4th Aug 2015 9:37pm
munch90
Just water wont hurt , then buy a bit of antifreeze to top up when needed next , the amount you would need to add after adding a header tank of plain water would be about half a cup full of anti freeze concentrate
dont waste your money buying ready mixed coolant , jusy buy 2 litres of anti freeze concentrate put it in a 5litre container and top up with water , that will give you the about right mix needed for uk weather
plenty of tests can be done at garage
pressurise system to check for external leak , or if it starts missing or white smoke ( steam ) poss headgasket
chemical test on coolant if exhaust gases getting in coolant when running
Post #443211 4th Aug 2015 9:40pm
shaggydog
Thanks Guys Thumbs Up
I have topped up with some of Kents best for now- tomorrow I have a 50mile round trip to work and back so will check at lunch time to see what is left. Will then grab some antifreeze (I'm guessing unmixed coolant is same stuff?) on the way home.
She has been running warm still so I'm wandering now if she has been getting too hot and boiling off out of the filler cap which has dropped the temperature.
I think a few tests would be a good idea, will give the techs at Harwoods something to scratch there heads over anyway!
No white smoke, no visible leaks, but coolant loss.
Engine running slightly hot, no misfiring, starts and stops fine, oil is clean and no bubbling or gurgling from header tank.
Its an odd one Neutral Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443219 4th Aug 2015 10:07pm
munch90
Something silly like weak cap
unmixed coolant = antifreeze concentrate ( it will say anti freeze concentrate on the container )
what colour is your coolant now ?
Post #443221 4th Aug 2015 10:11pm
shaggydog
I'll get one on order and give it a go!
I think my coolant is a sort of yellow-green colour. Hard to tell Embarassed Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443227 4th Aug 2015 10:21pm
munch90
Basic rule is only red with red
green and blue can be mixed
personally I would change to red, its more modern ( i know modern is not always the best! ), better for mixed metal engines, easier to find leaks, longer life
something like this
eBay Item No. 271084331150
You would need to flush out old coolant then replace with red
Post #443230 4th Aug 2015 10:34pm
shaggydog
I thought 200Tdi's cant use OAT technology because they have silicone parts? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443237 4th Aug 2015 10:56pm
munch90
Never heard that or anything slicone
Used red for years now
Post #443242 4th Aug 2015 11:03pm
munch90
This is the one ive used for years
eBay Item No. 330813222326
Except i buy it 200 litre at a time !
never known a problem with it
( think they got the price bit wrong for 1litre )
Post #443245 4th Aug 2015 11:08pm
shaggydog
Heh, you learn something every day.
Thanks for the recommendation Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #443249 4th Aug 2015 11:21pm
g-mack
i wouldn't use oat! lots about it being bad for older engines! td5 and later is for oat My 109 thread
my youtube channel
Post #443253 4th Aug 2015 11:40pm
munch90
A lot of that talk is on clasic cars with course cast iron heads and blocks
and quite often when you would change anti freeze it was the old style blue antifreeze that caused problem , ive seen water pump leak within 2 mins with fresh blue antifreeze
and it all boils down to the fact if you got a leak you got leak anyway !
Post #443259 4th Aug 2015 11:59pm
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Have you had any work done on the coolant system (before the hot & cold thread)?
Was it bled properly? if not, there could have been air trapped somewhere near the temp sensor, which as it moved around was giving you the hot and cold issue? and maybe now the void has corrected itself and dropped the coolant from the header tank?
If theres no leaks (or smoke) then its the only thing I can think of, unless someone is stealing it Rolling with laughter My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #443299 5th Aug 2015 8:39am
Page 1 of 4 1234>
