Home > In Car Electronics > Tweeters on top of dash
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
I want to install my tweeters on the top corners of my dash console. Any recommendations or advice? Is this going to be difficult? How about to feed the wires down? I will be mounting the Crossovers either under the passenger seat compartment(Left Hand Drive) or in the cubby. I have a small amp as well, which I will be mounting either in cubby or again under the passenger seat compartment.
Also, how difficult is it to remove the dash?
Post #442967 4th Aug 2015 7:50am
scotiach
Switzerland 2015 Defender 110 Puma 2.2 SW Scotia Grey
You won't need to remove the dash to install tweeters there. There's enough room to put your hand up most of the way from the speaker holes. There's space for an amp in the fuse box under seat compartment, but you should should probably not mount it to the floor of it. You might consider an under cubby riser to create a nice space for your crossovers whilst maintaining cubby storage (also raises the cubby to a good elbow height.). I bought mine here (on Wild Card 90's advice): http://offroadservice.net/innenraum/cubby-box-unterfach/index.php
Post #442974 4th Aug 2015 8:19am
They are also 1" in size. Thumbs Up
Post #442976 4th Aug 2015 8:35am
mk1collector
I did it and it's really easy but I'd recommend putting the crossovers behind the lower speakers and just running one set of speaker wire Back to the amp.
 Ray
My build thread
Post #442986 4th Aug 2015 9:14am
scotiach
Ignore my hasty reply above: I now see you don't have a Puma dash so I don't know about access. Sorry
Post #443084 4th Aug 2015 2:31pm
