Home > Maintenance & Modifications > Seatbox corrosion, how hard is replacement ?
Crs90
Evening all, I have taken all the mats etc out to clean round and have found some corrosion in the seatbox area at the rear on the drivers side.
What would you all suggest I do to halt it and also is seatbox replacement a big job and roughly how long does it take ?
Cheers Chris.
Post #442862 3rd Aug 2015 7:45pm
Crs90
Cant get the pic to come up, can anyone help ? (In very basic terms !)
Thanks
Post #442866 3rd Aug 2015 7:54pm
Here you go Chris.
Thumbs Up
Post #442867 3rd Aug 2015 7:57pm
Crs90
Cheers Steve, how did you do that ?
Chris
Post #442872 3rd Aug 2015 8:16pm
Enter your 'Gallery' then copy the link in the top box at the bottom.
Then paste into a post. Thumbs Up
Seatboxes, IIRC they are a case of drilling out the rivets and replacing then re-riveting.
Obviously using Ali rivets to match.
YRM do seatboxes I believe unless they are SS, not quite sure what they do.
I'm assuming you'd want them painted too, or not fussed?
There'd may be sone on eBay instead, or possibly a reputable breaker on eBay.
If your really really lucky even some in matching paint. Laughing
I'd certainly avoid private sellers though, you never know if your unknowingly buying stolen goods. Big Cry
Post #442893 3rd Aug 2015 9:39pm
Martin
Site Admin
Or "Add to my posting list", repeat for all the photos you want, when you then go to post on the forum the pic(s) will be waiting for you Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #442907 3rd Aug 2015 10:15pm
Mo Murphy
Chris, you are far far from even needing to think about seat box replacement.
If, in many years time, it becomes more than just offensive to your eye then YRM sell a replacement side panel for the seat box, which is not difficult to replace and replacement will keep you entertained for an afternoon.
My own early seat box had two much later sides scavenged from other scrap seat boxes 😊
HTH
50 Shades of Pennine Grey
Post #443340 5th Aug 2015 9:28am
Do YRM sell SS panels though or Ali as well?
Post #443359 5th Aug 2015 11:38am
Mo Murphy
I don't know Steve, a rummage on their website should reveal all. I wouldn't be all that keen on ss as it makes more electrolytic corrosion than mild steel when in contact with ally.
Post #443475 5th Aug 2015 6:11pm
Yeah, that was my concern and why I mentioned it.
Post #443504 5th Aug 2015 7:35pm
Other than holding the seats up, there is no real (I know seats are important) structural traumas. I've seen lots and lots worse. My old 90 I'm restoring (see v8 90 auto build thread) the seat box had a big alloy repair panel on it. I've luckily found a new old stock seatbox.
Answering the question, there are the 8 bolts holding the pair of seats in, remove cubby box if fitted, then you have to remove the floor panels, gearbox cover ( remove gear stick gators ) unbolt the handbrake and disconnect the handbrake cable.
Sounds a lot, though very very easy, the only difficulty you may encounter is rusted/seized bolts.
Post #443509 5th Aug 2015 7:45pm
Crs90
Thanks for the replies, plenty to think about Very Happy
Chris.
Post #443533 5th Aug 2015 8:24pm
