Home > Maintenance & Modifications > Dog Guard fitting in a 90 CSW: Help!
RRUK
So I now have my hands on a genuine LR006448 part dog guard that should fit my car, it came complete with brackets however mine already has them installed.
I printed out the LR Accessory install pages and I can see how it SHOULD all go it, but it doesn't line up at all. I can get the two tie bars on it that are attached to the wheel arch sides, but after that, nothing lines up.
There's two brackets on top of the wheel arches behind the front seats, the instructions show the dog guard in front of these but that's completely impossible due to the tubular bulkhead removal bar. Then the two brackets by the alpine lights are inches away too.
Can anyone offer any advice on this one? If I lose patience I will sell it on!
has anyone got one fitted in a 90 CSW with the bulkhead removal bar behind the seats? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #442798 3rd Aug 2015 3:58pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
I have this mine. its a bit fiddly until you work out where stuff goes. The bottom goes behind the bulkhead removal bars. but in front of the bracket. pictures here showing the left hand side looking from the back.
The top section goes agains the reader side of the bracket, screwing in from the front.
The bottom of the top pic sits on the bottom piece, forward of the screw brackets.
Do everything up real loos to start, then tighten it up. If all else fails take the brackets that are in there out, and use the proper ones.
Post #442844 3rd Aug 2015 7:03pm
RRUK
I just don't see how you've managed to put the dog guard in front of the bracket on the wheel arch and yet at the same time behind the tubular bar.
In this photo below you can see that both in mine are in line with each other. This is why I can't get it to fit.
 2016 D4 HSE
Post #444834 10th Aug 2015 11:25am
