Home > Td5 > Extending breathers. Possible problem?
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
I wish to extend my breathers and have a connector for the engine bay with 5 (3 in line and 1 each end) push fit connectors, I presume it was for the 3 in the engine bay and an extra for a 200/300tdi engine for the belt and the last to go up the snorkel. My thoughts are to utilise the spare one and extend the back axle and the fuel tank, one would be connected by a splitter then bring into engine bay and would only require a single tube up the snorkel. A thought has ocured that I may be causing a problem by joining the fuel tank and rear axle together and if I should go into water and the axles are hot that this would suck air in as expected but would I be introducing diesel fumes into the system and could it cause any problems (hope this makes sense). Regards
Dennis.
Post #442337 1st Aug 2015 10:53pm
munch90
personally I would keep the fuel tank on its own
as you say being at a extreme angle , cold water etc etc
Post #442358 2nd Aug 2015 7:16am
LinDens90XS
Thanks for that. for the sake of an extra pice of tubing it makes sense to keep them apart, after all it is only 2 pipes up the snorkel. Regards
Dennis.
Post #442544 2nd Aug 2015 8:52pm
