Home > Td5 > fuel pressure regulator replacement. |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
An easy fix on a Defender but takes twice as long in a Discovery2 (1h-2h)... it is only an oil seal that needs replacing under the circlip but everyone loves spending �150 on 99% needless parts. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
2nd Nov 2010 10:38pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Is that thru? Mine was leaking through the small hole in the part behind the circlip.
If you think that is still the case I take it apart and have a look. I spend a little less on the part but then with shipping and the seal I paid about the same. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
3rd Nov 2010 8:29am |
99% of the time it is leaking past the seal below the circlip. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
3rd Nov 2010 8:34am |
PeteA Member Since: 14 Jan 2012 Location: Lancs Posts: 44 |
Hi Red Dot, mines leaking quite badly and i was thinking of getting a repair kit but wasn't sure how good they are, I take it from your comment that you have good experience with the kits? Where did you buy it from and do you have any part numbers. Cheers Pete |
6th May 2012 8:25am |
So i bought a seal kit off ebay for a tenner delivered and fitted it on Saturday, Red Dot was right the leak has been cured. Curiously the o rings on the regulator looked ok but I changed them any how.
14th May 2012 11:30am |
Must have been a popular pastime this weekend Did mine on Saturday, I've a feeling mine was leaking on the lowermost fuel pipe but did all 'O' rings and seal plate anyway. The smaller 'O' ring on the plunger was damaged slightly and the lower fuel pipe one didn't come out with the pipe, maybe it had detatched from its seating position over time. Time will tell whether it's made a difference, just got to let the previously spilt diesel/oil dry off
Simple enough job, just access issues with shovels instead of dextrous hands on the ends of my arms, bit like taking the starter motor off, it's the bolt you can't see that's the pain. Would have been easier if the inlet manifold were to be removed but who does that anyway You just struggle on, swear a lot and feel smug when it's done p.s. good one for LRS Offroad for ease of getting the parts through fleabay, but I'll be back if it leaks again |
14th May 2012 11:44am |
Andrew DefenderBits Member Since: 15 May 2012 Location: Somerset Posts: 43 |
we supply a Viton seal kit and have had lots of good feedback that this does the job instead of replacing the whole thing. Not done one myself so can only go on feedback from customers though.
18th May 2012 11:27am |
