Home > Maintenance & Modifications > Immobilisation while away on holidays
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Hi all,
I have a 300Tdi and off to sun myself for a couple of weeks tomorrow. Although my Defender can't be seen from the road I'm keen to reduce the risk of theft whilst I'm away. I can't get it in the garage so was wondering if anyone has any tips for immobilising it in some way.
Other that taking the wheels off (it might come to that Laughing ) I'm struggling to think of anything.
Any ideas?
Many thanks,
Andy
Post #442054 31st Jul 2015 10:13pm
Set up a geofence if you have a tracker.
Post #442055 31st Jul 2015 10:15pm
Silver Back
No tracker Steve I'm afraid Sad
Post #442056 31st Jul 2015 10:18pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
For a bit of time but zero cost how about removing the battery and every fuse in it? Would certainly slow them down and eliminate a simple break in and drive away? Obviously would stop any alarm working though so would have to weigh up benefits vs down sides? just a thought...
edit: axle stands and remove all wheels as well?
Again a bit of hassle but you might relax better on holiday?
Front seat(s) out, steering wheel off? Not feasible as a daily routine, but as a one off to increase chances of it being there when you get back...
Post #442058 31st Jul 2015 10:21pm
munch90
Maybe a friend with a garage
Post #442060 31st Jul 2015 10:23pm
Silver Back
Thanks all.
Some good ideas for me to mull over this evening. Thumbs Up
Post #442063 31st Jul 2015 10:36pm
fathaggis
sell it Big Cry
Post #442065 31st Jul 2015 10:40pm
munch90
Short term storage place , if there is such a thing
Post #442066 31st Jul 2015 10:40pm
grumpy old git
I always take the OSF wheel off if we're away for a few days and leave it on axle stands. Hopefully it'll put them off if it's obviously going to be hard work to tow or drive. We've taken other precautions but this is the only obvious one.
Post #442080 1st Aug 2015 12:16am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Pedal box lock, steering wheel off, selector leavers off. You could always take the steering rod off and the front prop that would make it hard to drive away. All these are easy to remove and only a few bolts but can really be effective, just remember to leave the transfer box in low ratio and NOT in diff-lock.
Post #442083 1st Aug 2015 2:03am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Removing the ECU will prevent it being started and with no quick fix, other than that consider a secure carpark nearby. Oops 300tdi Embarassed Original Member Pie n Pea Club.
110 HCPU Tipper
Post #442093 1st Aug 2015 7:16am
Wheel off is a good idea
300's don't need electric to run but the fuel solenoid does, maybe disconnect that too ?
Post #442095 1st Aug 2015 7:19am
g-mack
Disconnect a track rod! Stuff rags in air duct to stop air flow, pull wire on stop solenoid, My 109 thread
my youtube channel
Post #442130 1st Aug 2015 10:24am
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
Either take 2 wheels off or a wheel and the spare.....that way they cant use the spare to replace the wheel you've removed Wink
Post #442133 1st Aug 2015 10:47am
Local authority quality wheelclamp.
http://www.elitesecuritysupplies.com/wheel...clamp.html
Fits perfectly on a Defender, and is a local authority approved design.
Post #442149 1st Aug 2015 11:43am
