Home > In Car Electronics > Puma speaker/Radio upgrade
Jamesjames999
Hello all, i have now had my 2011 puma for a few months and i think it is time to upgrade the speakers which come standard.
I want to keep my Landy as original as possible and not keen on cutting holes in the dash so anyone know any high quality 4" speakers which have a lot more bass etc, i am happy to fit spacers but I'm just not sure what speakers and if i will have to change the radio as well.
I know there have been a lot of posts made on this site about upgrading speakers but from what i have understood is that not all speakers will work with the standard LR radio as the power draw.
Like i said i want a pair of speakers which have a good amount of Bass as the speakers which come standard are very tinny
thanks
James
Post #441944 31st Jul 2015 1:33pm
4" Speakers only good for Mid & Hi tones even the best wont give the lows you wish for Thumbs Up
Post #441947 31st Jul 2015 1:41pm
Jamesjames999
Thanks for you're reply, yes i am aware that 4" speakers are very limited on the bass side but what do you recon i am going to get the best results from?
Also would a flat sub be easy to install?
thanks
James
Post #441960 31st Jul 2015 2:27pm
Not much extra bass yo get but you can improve some mid range and quality.
13cm is possible providing your happy to cut the dash.
Personally I'm not sure if I like the look of 13cm in a Puma dash.
Looks a bit like Beverly Hills women. Shocked Whistle
Post #441963 31st Jul 2015 2:39pm
jimbob7
5.25 inch speakers fit with 25mm MDF spacer rings and minimal cutting.Lower dashboard is made with 5mm foam 1mm (approx) mild steel. Pov.spec,ftw. 2006, 110,TD5.
Post #441975 31st Jul 2015 3:35pm
From experience
Upgrade the 4" to Crossover Focals inc tweeter upgrade
Then 6x9 fitted Midships in custom Box & Focal Sub powered by an appropriate amp
Don't forget ample sound deadening Thumbs Up
Post #441980 31st Jul 2015 3:58pm
"Don't forget ample sound deadening Thumbs Up "
Very true, perhaps THE most effective upgrade.
Post #441983 31st Jul 2015 4:01pm
Jamesjames999
Thank you all for the feed back, and do the Tweeters make a bige difference? where did you purchase for focal tweeters?
Also my Defender so only has the dash speakers Smile
thanks
james
Post #442849 3rd Aug 2015 7:16pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
James,
If you don't already have tweeters they make a massive difference, make the sound feel like its coming from the screen rather than your knees, also they allow the driver to concentrate on the mids and some lows and the tweeters just the high's.
If you have the stock tweeters then upgrading them and the stock speakers still makes a good improvement in sound quality.
Well worth installing a good set of components.
Sorry ignore me im clearly having a senior moment at 40!! getting confused with another thread about tweeters. I have focals 100 krs but they certainly do not increase the bass on their own the fronts are all about sound quality and bass is picked up by a sub on the cubby or elsewhere depending on where you want to put it.
Post #443001 4th Aug 2015 9:47am
Grenadier
Doesn't the bass rattle the pannels so much they drown out the music? Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #443003 4th Aug 2015 9:55am
Not if you use sound deadening material
Post #443033 4th Aug 2015 11:41am
Snowy90
Ken how did you fix down your 6X9 speaker pods to stop them moving in emergencies or any other time.
Ta
Chris
Post #443034 4th Aug 2015 11:45am
Sound deadening I,proves the sounds anyway, not only does it reduce vibration.
It reduces engine noise and improves sound quality to boot on top of that for this very reason.
Where possible any speaker / sub that produces good bass should be secured well to a solid part of the body.
Not always possible but should be an aim to make.
Post #443051 4th Aug 2015 12:35pm
Grenadier
After three 4 hr stints driving through Italy over our long weekend just gone, I think my wife is very convinced by sound deadening!! So it will definitely be going in over autumn. Now I just need to convince her of the validity in a Bowler Stage 2 tune.... Whistle Monsieur Le Grenadier
Post #443052 4th Aug 2015 12:37pm
"Now I just need to convince her of the validity in a Bowler Stage 2 tune.... Whistle "
Increases MPG of course. Whistle Rolling with laughter
Post #443096 4th Aug 2015 3:02pm
