Home > Td5 > Replacing steering dampner
excossack
Going to replace the steering dampner with a new one. Is it just a case of undo the bolt at one end, undo the nut at the other, remove it,replace and then do up the nuts? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #438924 19th Jul 2015 3:39pm
munch90
Basically yes
Post #438925 19th Jul 2015 3:45pm
excossack
Thumbs Up 1999 Defender TD5 110
Regards
John M0VAZ
Post #438926 19th Jul 2015 3:53pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
munch90 wrote:
Basically yes
What are the symptoms of a dead steering damper?
Wandering the road perhaps?
Andy
Post #441566 29th Jul 2015 11:36pm
munch90
for a wandering problem damper would not be my first thing
play in steering box
play in track rod ends
tracking
uneven tyre wear
damper
damper is mainly for wheel wobble
Post #441579 30th Jul 2015 5:36am
excossack
I am only replacing mine because;
1. I have a new one
2. The current one if original has done 183016 miles! 1999 Defender TD5 110
Regards
John M0VAZ
Post #441594 30th Jul 2015 7:04am
ROBBONTHEROCK
Funnily enough I was considering doing the same, as you say not for specific problem just the fact that it has done 173k.
Andy
Post #441596 30th Jul 2015 7:09am
excossack
That for me is enough really. I do get a little wobble so maybe it will help, 1999 Defender TD5 110
Regards
John M0VAZ
Post #441600 30th Jul 2015 7:23am
munch90
On all my defenders ive always run 2 steering dampers , 1 in standard place , 1 behind axle
Post #441715 30th Jul 2015 6:12pm
RRUK
When I removed mine, there was no rebound left in it, I'd compress it and it didn't rise back up. I put a Supagaz one on from Paddocks. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #441717 30th Jul 2015 6:22pm
munch90
They shoudnt push out on they own anyway
if you push it half way it should stay there not push out
about the last thing you want is a gas one , because gas one pushes out and will tend to try to push steering arm and make defender pull over one way all the time ( ok only slightly but it does )
Post #441723 30th Jul 2015 6:30pm
RRUK
If that's the case then why do they make them in the first place and how come I've never read anyone slating them before?
Why would people like Bilstein make and sell them?
http://www.paddockspares.com/stc786b-steer...in-b6.html 2016 D4 HSE
Post #441724 30th Jul 2015 6:33pm
munch90
if the damper pushes out it will tend to try to turn the steering , making the vehicle pull one way
As said it may be slightly but it does , and personally i think a gas one is a waste of money , after all the gas one ( or any gas damper steering or wheel ) still use oil as the dampenning the gas is only to pressurise the oil to help stop it foaming when they worked hard , something i doubt would ever happen on a defender
Post #441733 30th Jul 2015 6:57pm
ROBBONTHEROCK
Any more details.
Are they both standard LR units?
Is the second one mounted to existing mounting points or are did you make bespoke mountings for them?
Andy
Post #441735 30th Jul 2015 6:59pm
munch90
Yes both standard ones , 1x all standard in standard place , but because of the angle its at its not really that good
some use the discovery rod thats uses a damper behind axle , but ive always just made my mounts , one end mounted of diff nose and one on steering rod and beause its down in a much straighter line with the rod its a lot more direct acting on the steering
Post #441737 30th Jul 2015 7:05pm
