Home > Maintenance & Modifications > Remove cam/rocker cover |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 371 |
Hey,
So I made a start on trying to find and fix a ? fueling issue ? today (More here http://www.defender2.net/forum/topic38392.html) and when I removed the cam/rocker cover I found this! Now all the images I've see when looking into how to change the injector seals etc have far cleaner heads! I'm not sure what exactly is causing it or why, the oil on the dip stick is crystal clear and its serviced every year. I hope people don't mind me starting a thread on here as it has a bigger audience than the TD5 threads and I'm sure most/a lot of people will have had a TD5 at some point. Click image to enlarge Thanks 2006 Defender Double Cab- Zambezi Silver |
22nd Jul 2015 11:16am |
Pretty much the same as mine was when I last did mine. Some people can't help themselves and cannot resist cleaning and polishing everything in sight before taking pictures
22nd Jul 2015 11:23am |
