Home > Puma (Tdci) > Puma, not starting and no dash
Loud40
Wales
Hi every one, wonder if any one could help, got a really strange fault on my 57 plate 90, somehow i have lost all my dash lights/ fuel gauge/ temp gauge, only warning light that is working is the handbrake warning light!! Lights wipers ect is working fine...
And on top of that she has decided to stop starting too, when i turn the key the starter motor would engage for about a second and then drop out, if im really lucky she'll turn over as normal, fire up for about two seconds and then cut out, that only happens about one out of ten times, still with only thehanbrake light on.....
OBDII connects and shows no faults.... Any help would be greatly apreciated!!
Post #439221 21st Jul 2015 5:35am
munch90
first simple thing to try is to disconnect battery for 5 mins then reconnect and try it
Post #439224 21st Jul 2015 6:01am
Loud40
Wales
Hi munch, tried that, checked all the fuses with a multimeter, and the relays, main, starting ect... Plus changed the ignition switch, but still no hope.... Sad
Post #439239 21st Jul 2015 7:01am
Roy5695
I'd be looking for a broken earth strap. if as you say fuses are all intact...
Post #439259 21st Jul 2015 8:15am
Loud40
Wales
Thanks for the help, ill have a little look after work Thumbs Up
Post #439329 21st Jul 2015 12:32pm
Fifth Horseman
Did you check all the fuses in both fuse boxes and the large fuse in the drivers seat box?
Has any work been done on the vehicle recently?
The (non) starting issue has the symptoms of an immobiliser fault.
Check the plug in the rear of the instrument panel, IIRC the immobiliser/alarm connects to the engine ECU (EMS) via this and the EMS controls whether the starter operates. A problem with this connector or (hopefully not) with the instrument pack could cause the problems you are having.
You say ODBII shows no faults, what code reader are you using, most generic ones only connect to the EMS. You need to check the instrument pack and alarm unit for fault codes as well.
Post #439333 21st Jul 2015 12:47pm
