Home > Technical > Bonnet inserts
brightondefender
2010 Defender 90 Puma 2.4 XS CSW Alaska White
Bonnet inserts
I have just replaced the plastic bonnet inserts in the hinges as the bonnet was making an almighty rattle - but they still aren't tight enough in the hinges to stop the rattling.
Does anyone have any other suggestions? I'm wary of trying to close the hinge up as I reckon the paintwork will crack. The replacement inserts are genuine LR as well!
Rolling Eyes
Post #438734 18th Jul 2015 12:32pm
JWL
Years ago on an older 90 I cut some strips of bicycle innertube and placed it in the "hook" part of the bulkhead then put the plastic inserts in and put the bonnet back on. That stopped the rattle on mine and you could hardly see the rubber.
Post #438739 18th Jul 2015 1:19pm
brightondefender
Sounds a brilliant idea I will give that a go. Many thanks Thumbs Up
Post #438740 18th Jul 2015 1:22pm
Or you can get small neoprene rubber sheets on eBay, both do the same job.
Post #438744 18th Jul 2015 1:55pm
ericvv
Re: Bonnet inserts
Rolling Eyes
Here is a suggestion which will work.... Guaranteed rattle free. Thumbs Up
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #438746 18th Jul 2015 2:01pm
