![]() | Home > Other Site Sponsors > [For Sale] PUMA overheat? We have the cure! |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
This spacer will move the Visco fan nearer to the radiator and imoroves the airflow. This prevents the overheating situation which occures sometimes in hot areas. Fitting is simple
Available in the UK through www.4x4overlander.com Rest of the world www.nakatanenga.de http://nakatanenga-tours.de/shop/system/de...sition1%26 http://nakatanenga-tours.de/shop/article_V...SKODIST%26 WANTED: SII or SIII in max 1.5k |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
sorry if this comes across as rude
does it really make that much difference? |
It does make a difference! Scangauge shows upt to 15° C difference WANTED:
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 ![]() ![]() |
No, Nakatanenga just spent months on desert expeditions and months in engineering plus thousands in insurance and TUV fees to bring you a piece of metal that does nothing other than allowing them to post an excited 'we have the cure'. I'm left wondering if someone turned around to GlaxoSmithKline and asked the same when they announced they had found the cure for malaria? ![]() Sorry, forgive the sarcasm, but Nakatanenga are too polite to respond other than in a positive manner, so I thought I'd do it for them and everyone else. ![]() |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Interesting...
15°C less means a lot. Now we are in the middle of the winter and my motor shows maximum around 90°C-96°C. I don't need it rigth now, but probably I will buy the piece in Oct-Nov. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
@Projectblue
Do you have personal data/experience that it does/doesn't work? It's hard to make an informed decision based on statements alone ![]() Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Erm, say it simple: There are so many improvements which were not made by Rover, British Leyland, Land Rover, JLR, Tata and so on..... WANTED:
Indeed
![]() I was just wondering if there were any user experiences to go on but I guess it's still too new... Seriously though, can you think of any possible negative effects/situations? I am always interested in improvements, especially when the temperatures are climbing so high around here. Cheers Matt p.s. still loving the aerial - reception is so much better than the original ![]() But shout it at them in German because life is also terrifying and confusing... |
Wont drop temp below thermostat temp ,
^^ That's where PEL500110 comes in the game.... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
PEM100990 - Cream is 88° With hard Spring ( standard fitment on defender )
PEM101020 - Black is 82° With Hard Spring ( this one I found ok for colder uk weather , dropped running temp a bit and stayed steady ) PEL500110 - Grey is 82° With Light Spring ( found this one took to long to warm up in uk weather and temp went up and down , GUESS AS I NEVER TRIED IT IN HOTTER CLIMATES . it might be good for hotter climates ) this is what I found after trying all three ONLY IN THE UK , but how you drive , what you tow , outside temp etc may give you different results |
Seriously? ![]() ![]() Ok, even if you leave out the design faults they never rectified, there are the engineered to a cost aspects (found in most vehicles). Just look at things like; Rear door hinges on 110 to increase opening Rear door stay improved resistance. EGR blanking That's 3 without even trying. Ask yourself this. Would a serious aftermarket supplier, where reputation is EVERYTHING, make a product that was 'Emperor's New Clothes'? ![]() |
it was a simple question having never heard of a puma overheating before. and yes i have experience of multiple puma's in hot climates. maybe not as much as them but. |
Apologies. I didn't think asking for more information, forum members' experiences etc. would hit a nerve. In any event, don't be too näive - I've had a few "lemon" products before now from various suppliers (but I'll not mention those...) Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
