Home > Maintenance & Modifications > Receiver hitch question
Page 2 of 2 <12
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Brendan, so if I'm paying £220 yr road tax (MY2011 Puma 90 xs), this is classed as a commercial? And towbar doesn't need to be type approved?
Cheers, Andrew 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #290497 15th Dec 2013 4:06pm
x-isle
Tough call that one, but even so, if it doesn't have to be approved, your insurance co. may think different? Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #290523 15th Dec 2013 5:22pm
leeds
Cheers, Andrew
I believe that is classified as a commercial vehicle and hence does not legally have to use type approved towbar.
Now can/will an insurance company require you to have fitted something that the law does not require? That is not a question I can answer. That is between you and your particular insurance company.
Brendan
Post #290562 15th Dec 2013 7:17pm
landys1
Ok, thanks, better check with the insurance company then to be on the safe side 1959 Series 2 Ragtop
2011 Puma 90 2.4 XS
Post #290595 15th Dec 2013 8:26pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
My 1998 Defender is classed as a commercial van because it came out of the factory as a hard top (no windows and no seats in the back, ie. not a Station Wagon). It has had windows put in later and at one time also had seats in the back, but it still retains its 'hard top' identity.
As it is pre-2000 I pay the same VED as a same age SW though, so it is really only on newer post-2000 vehicles that checking what amount of VED you pay tells you what class it is.
My 90 is also classed by the insurance people as a commercial van. The insurance company has access to a database which decodes chassis numbers and tells them if a vehicle is a commercial or not. I used to have mine insured as a private car until the insurance companies got this database. Now it has to be a commercial and I have to stump up about £100 more per year to insure it as a consequence! Sad However, it does mean I can legally use a receiver hitch Wink
On older models like mine it doesn't tell you much on the V5C, and of course the body type may have been changed before your ownership, but the VIN number code can confirm the original classification. FirstFour have conveniently provided a decoding page to help you work out what your own vehicle is. http://www.firstfour.co.uk/products/land-r...nformation Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #290674 15th Dec 2013 11:11pm
jst
Cheers, Andrew
correct its commercial, you dont need type approval towing. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #290832 16th Dec 2013 5:10pm
landys1
Great, thanks for that Thumbs Up Makes towbar choices a lot easier... 1959 Series 2 Ragtop
2011 Puma 90 2.4 XS
Post #290833 16th Dec 2013 5:18pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
x-isle wrote:
Finally got around to fitting the Safari Equipe Receiver supplied by Brendan (AKA Leeds).
Thumbs Up Top piece of kit, although I won't be leaving the recovery receiver left in.
This looks ideal.
I cannot see this part on the web site mentioned; does anyone know of another source for it? I assume it isn't simply the plate but also the support underneath?
Post #438405 16th Jul 2015 8:37pm
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
AM94,
Contact Leeds, Brendan at 4x4 Overlander , and I'm pretty sure he will be able to supply, as I bought mine from him. Kit includes plate and support, plus ties to chassis. Other parts such as recovery pintle and drop tow hitch were extra.
Worthwhile modification for my use.
Good luck
Post #438439 16th Jul 2015 10:14pm
Mr Fox
Thanks DC101 - will do
Post #438506 17th Jul 2015 9:24am
nakatanenga
Germany
Together with a Type approved Towball this is a perfekt combination:
http://nakatanenga-tours.de/shop/article_A...KMM-030%26 WANTED:
SII or SIII in max 1.5k
Post #438510 17th Jul 2015 9:33am
Brewstop
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
Is this the type approved one? Sandy
Post #438618 17th Jul 2015 7:07pm
Page 2 of 2 <12
