Home > Td5 > Roamer Drive (Rover Drive) |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Hello Little Tom, Do you have MPG yet?? I am trying to justify the cost with the increased MPG. Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
13th Jul 2015 7:07pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Brilliant piece of kit, isn't it? They are made just down the road from where I live in Vancouver by a wonderful chap named Ray Wood.
I have had mine for 6 months now, and can't imagine driving my Td5 without it. I have been getting a pretty consistent 28 MPG |
14th Jul 2015 3:08am |
Double_R Member Since: 05 Apr 2015 Location: Kent Posts: 6 |
I considered the overdrive for my TD5 but in the end went for a new 1.2 gear set from Ashcroft because the garage told me it would be more reliable. As it turns out I had to have the gears replaced under warranty due to excessive noise!
Be interesting to know how the drop in revs compare between the two options, also is there any additional transmission noise with the overdrive? If I had the money I'd like to have the overdrive in addition to the 1.2 gear set I think this would be the ultimate. |
14th Jul 2015 9:02am |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Cant remember exact figures, but the Roamerdrive is something like a 28% drop in RPM, the 1.2 is 16-18% I think.
The 1.2, plus Roamerdrive might be a little to far on the Defender TD5. Depending on what set-up you run of course. |
14th Jul 2015 9:23am |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
I run a 1.2 transfer box on my TD5 and its great, but it needs the ECU remap.
Its a bit sluggish when cold, i.e. need to give it some revs when pulling away in first, but once warmed up its ace. Not noticeable in Summer, but is in Winter. I would say that if you can keep the standard transfer box and use a roamer drive to get the gearing you want that would be the best in my mind. I don't tow with my landy, but if I did i'm willing to believe it would be a bit sluggish in the winter. Cheers Andy |
14th Jul 2015 11:56am |
Guzzio Member Since: 09 Feb 2014 Location: Belgium Posts: 29 |
With the overdrive fitted, does the cruise control still works when overdrive engaged?
14th Jul 2015 12:23pm |
How much did you get before the Roemerdrive?? Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
14th Jul 2015 2:37pm |
I was getting about 25 -26 mpg. Now it's 28-30mpg. Depends on how much highway driving I'm doing. Best mileage was a 19 hour drive to Utah, 30MPG, I was doing an average of 125kmh
taazzukcb- you are correct on the RPM drop. 28% when engaged. |
14th Jul 2015 4:34pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 616 |
Try this to calculate you drivetrain ratios:
http://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html I have Disco2 TD5 - a bit tuned on 235/85/R16 tyres, heavily loaded (4 people, roof tent, ...) and Defender 130 TD5, pure standard on the same tires. Disco is much heavier to start moving of the car, than the 130, need more clutch action. The only difference is the transfer box ratio - Disco has 1:1.2, 130 has 1:1.4. For 130 I have prepared a bit bigger tyres 255/85/R16, overdrive and 1:3.8 gears to both diffs. This will make the car a bit slower without overdrive engaged and faster with engaged. So I hope, it will be fine on small roads and light offroad without overdrive engaged, and on highways with overdrive, to reduce the high RPM. Current Disco is fine on highways or offroad, tuned TD5 has plenty of power, but need a bit more clutch action. Last year during our trip to Alps I had to use low range too often, to save the clutch, when we were over 2500 ASL. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
14th Jul 2015 5:41pm |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 |
After a drive down from Preston to Portsmouth and then Cherbourg to Santander with various adventures on the way, I can honestly say the roamerdrive is a brilliant addition. Comparing last years trip round France with this years, the volume levels and driving comfort are vastly improved, it really came into its own on the French motorways. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
3rd Sep 2015 12:47pm |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 266 |
I've got 2 of them, one in my Series III and one in gertie, one of our 110's. Took Gertied round France, 4 passengers, roof box, back full of camping stuff and 5 bikes hanging off the back. Never bother coming out of overdrive. Got a consistent 26 - 27 mpg. At home we get 28mpg.
Hard to tell what mpg on the Series III, needs a new carb fitting, the old Zenith is way past its best. When I've got the cash definitely going to upgrade Effie our other 110. A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
16th Oct 2015 4:14pm |
and being able to drive on a highway and do this .....
Click image to enlarge is FANTASTIC!! |
16th Oct 2015 4:54pm |
Ok folks with Roamerdrives... Updates on how your overdrive has faired since 2015 if you please... On the verge of pushing the OD button. thanks
16th Oct 2019 7:48am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2757 |
I believe a compromise is to use the Ashcroft 1.3 gear ratio set in the transfer box, rather than the 1.2
While not as good as the Roamerdrive, it’s an improvement on the standard 1.4 gear set without the expense or issues with first gear being too high. |
16th Oct 2019 8:06am |
