![]() | Home > Off Topic > Plastering |
Tia4 Member Since: 15 May 2012 Location: Surrey Posts: 48 ![]() ![]() ![]() |
After a bit of advice need to sort out a bathroom ceiling its lath and plaster with a few cracks but otherwise sound should I over board first then plaster or will I be ok to plaster over the top.also it's Been painted so does this need to see led with pva first.
jaydt Member Since: 31 Aug 2013 Location: west midlands Posts: 36 ![]() ![]() |
Personally I would overboard and use plasterboard screws and not nails then skim without the need to pva.
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Double tack it and then plaster over 1951 80" S1 2.0
Had a loft conversion a few years ago and the disturbance caused the plaster to break off the lathes, it was only the paper holding the ceiling up. Just pulled the lot down, plaster-boarded and skimmed.
![]() Treat every day as if it is your last....one day you will be right!! |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Over sheet it with plasterboard and skim it, gives the best finish
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
