Home > Puma (Tdci) > Puma engine changes over the years....?
Amos
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Has there been any changes to the Puma engines and gearbox since it came out...?
Post #43479 25th Oct 2010 2:22pm
RED-DOT
I never realised the Puma engine may be Gay...... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #43480 25th Oct 2010 2:36pm
MK
Do not know about the Engine itself (at least the EGR valve). I know the gearbox& components had some "improvements" (whatever that may mean for LR) Puma 110" SW
Post #43485 25th Oct 2010 4:26pm
Amos
Anyone else know if anything else has changed....!
Post #43600 26th Oct 2010 7:50pm
Caterham
not really engine....
but didn't someone on here suggest the brakes had changed from bosch to somthing else and it was suggested to be a cheaper alternative?
Post #43634 27th Oct 2010 7:19am
Grockle
just have a look on here, early models had Transit clutches which weren't up to the job,sticking piston cooling jets and the brake vac pump which is on its third version
so really don't buy an early one,unless all the recalls have been done.
good luck 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #43636 27th Oct 2010 7:53am
mse
Not all the issues are on early ones - there are faults dotted all over the 07-09 range by 09 most niggles are fixed. Mike
Post #43674 27th Oct 2010 4:09pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Only took 2 years to sort them out Rolling with laughter
Post #44183 2nd Nov 2010 7:42pm
Caterham
after having a look under the bonnet of a 2011 MY it looks different in many areas but I'm not sure if thats my poor memory or not?
Post #44200 2nd Nov 2010 10:29pm
mse
Less paint and poorer memory Mike
Post #44205 2nd Nov 2010 10:43pm
RED-DOT
I am currently driving a brand new 60 plate Defender in white with white steel wheels with Michelin 7.50 Mud biased tyres. It does not have one accessory at all and compared to my 2007 90XS i have noticed these differences... it is much better on Diesel, the interior only has rubber mats and is therefore very noisy, the engine is a bit more lively. It has a wiper motor that is so noisy you tend to only swipe once in everything but a downpour. There is only a shiny loadspace area which is deadly on wet wellies and paws. It would snap your spine on pot holed roads and tracks. I like the new sidelights that also glow in the headlights. The road noise is worse on the 7.50 Michelins than my 265 BFG M/T's. The paint is absolutely flawless and looks deeper the the Stornaway of my own Defender. The panels are not as stressed as mine.
I like the pureness of the new one and it is maybe the way a Defender should be, do we really need all the carpets and fancy wheels? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #44207 2nd Nov 2010 11:24pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
"I like the pureness of the new one and it is maybe the way a Defender should be, do we really need all the carpets and fancy wheels?"
erm..........Yes
call me an old softy but i like the soundproofing and all the gadgets.
having said that i quite fancy an SIII or 2A simply for that purity as a hobby and weekend fun.
the XS is for everyday use. Thumbs Up BM52
Post #44212 2nd Nov 2010 11:43pm
