Home > Puma (Tdci) > 2.4 Turbo - intercooler pipe/baloon!
Soupy
We had issues with an 08 2.4 110. In the end we discovered the turbo vanes were stuck. We replaced the turbo and all seemed fine.
As a precaution we replaced the intercooler pipes (turbo - intercooler & intercooler - inlet) at the same time, this is about 4 months ago.
This morning the turbo - intercooler pipe burst:
On removing it and comparing it to the one we removed 4 months ago, it would seem something isn't right:
The new, burst one is the black one. As you can see it's been taking some pressure and has ballooned somewhat. We've replace the pipe now it there is no blockage in the intercooler.
Any ideas?
Post #436321 7th Jul 2015 12:37pm
ericvv
It happens. I once had that same standard intercooler pipe burst too and then it was replaced by a new standard one. You can buy aftermarket silicon pipes from various suppliers, or you can go all the way for stainless steel as I have done recently, and which is a permanent solution. I bought these stainless pipes from Entreq which is top quality. Installation can be a pain though, which in my case was alleviated by having Entreq do the installation themselves at their workshop. You can read more in below thread.
Eric
http://www.defender2.net/forum/topic37404.html You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #436342 7th Jul 2015 2:32pm
Soupy
Having replaced the pipe already, what I'll probably do is fit these if the issue arises again:
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...35d221e3c5
Seems strange that the pipe should balloon and fail in such a short time without there being an issue somewhere. It was a genuine LR replacement pipe too.
Post #436350 7th Jul 2015 3:33pm
ericvv
Post #436355 7th Jul 2015 3:55pm
Soupy
For the £30 odd quid it cost I doubt I'll bother. We fitted it ourselves anyway.
Post #436367 7th Jul 2015 4:37pm
