![]() | Home > Maintenance & Modifications > Drivers Window packed up...... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20634 ![]() ![]() |
Check and trace wires, especially around the area where the rubber joint goes between the door and body.
They sometimes break / degrade. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5813 ![]() ![]() |
That will be the wires in the rubber trunking going from post to door. Very common, pull boot out both ends and inspect the two thick wires, and give them a pull. You may even find window works at certain door open positions.
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Mine did this, I just cut out the wires that had gone brittle and spliced in some new, if you do go down this route then make sure you leave a bit of extra cable (just a few inches) more than it was originally, it just helps it not to pull too much when the door is fully open
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 ![]() ![]() ![]() |
Did this last weekend. Drivers window would only open/ close with door at certain angle, found white wire in rubber between door and post in two. Spliced new section in and all is well.
Had a similar problem when I bought it with central locking in rear drivers side door not working. Found to be broken wire in rubber tubing. Defenders!!! ![]() |
